r00ter
PC Specification: gtx260, Qcore@3ghz, windows7x64
Re: Splash Lite 1.2
Sun Jan 17, 2010 1:03 pm
applejack nice hint i almost forgot to use this ;)
i also found an incompatible audio stream found in a lot of mkv files.
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 509 MiB (4%)
elvissteinjr
PC Specification: AMD64 2GHz, ATI Radeon HD 4670, Vista 64
Re: Splash Lite 1.2
Mon Jan 18, 2010 1:55 pm
Helios wrote:
elvissteinjr wrote: SplashLite 1.2 crashes when I try to open a XviD encoded AVI file. I don't if it's the file, but it could be played normal in all previous versions.
SplashLite is a new generation player focused on HD best quality compression standards (like H.264). For backward compatibility uses system codecs to support older lower quality standards (like Xvid). Please ensure you have installed stable Xvid codec in your system.
Please try again one of the previous SplashLite versions to determine if your avi file would be played properly on actual system codecs setup. It would be very helpful feedback.
I didn't re-install an old version, but didn't change any codecs before updating SplashLite. Windows Media Player playback works fine. ISplash crashes at all XviD encoded AVIs. It would even been great if there would be just an error message.
Watchman
Re: Splash Lite 1.2
Tue Jan 19, 2010 3:24 pm
r00ter wrote:applejack nice hint i almost forgot to use this ;)
Format : AC-3
Codec ID : A_AC3
Bit rate : 448 Kbps
Hello r00ter,
What do you mean by "incompatible"? Is the info panel showing "Not supported" and there is no audio?
Thanks.
r00ter
Re: Splash Lite 1.2
Tue Jan 19, 2010 5:02 pm
oh sorry :D
no audio is available. no error msg is shown. there is just nothing to hear just the video is shown there is also no audio leveling available for splash in the windows 7 sound mixer if this type of audio is used. the other types i know are working.
edit :
if i try to use the info panel this happens :
Code: Select all
( if i don't try to use the info panel splash plays this videos without any error but without sound ;) )
my system is a mostly uncustomized win 7 x64 system.
the audio/video codec ( A_AC3 / h264 ) the file it self is working on all other players i knwo : mpc, mpchc, wmp11, gom, winamp, vlc and so on
exact info of the filetype.
Code: Select all
Format                           : Matroska
Overall bit rate                 : 11.4 Mbps
Writing application              : mkvmerge v2.9.7
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Bit rate                         : 10.1 Mbps
Nominal bit rate                 : 10.4 Mbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 23.976 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.275
Writing library                  : x264 core 79 r1347 5ddd61b
Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=10350 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.10 / aq=1:1.00
Format                           : AC-3
Codec ID                         : A_AC3
Bit rate                         : 448 Kbps
i hope this helps you i bit.
Helios
Re: Splash Lite 1.2
Tue Jan 19, 2010 9:18 pm
elvissteinjr wrote:I didn't re-install an old version, but didn't change any codecs before updating SplashLite. Windows Media Player playback works fine. ISplash crashes at all XviD encoded AVIs. It would even been great if there would be just an error message.
Could you please specify what Xvid codec have you installed. Could you also try Xvid video in other containers (like MP4, MOV, MKV) ?
Unfortunately we cannot reproduce the problem in our test labs, your feedback would be very helpful.
reb0rn
PC Specification: Celeron ULV 1.2, intel 4500HD, Win 7
Re: Splash Lite 1.2
Wed Jan 20, 2010 3:00 am
Very nice player :)
Could you pls add Subtitles encoding not to be predefined by system default so i can change it manualy...in some next version pls
Also is there a plan to support analog TV cards ?
ethaniel
PC Specification: Phenom II X2 545, Radeon HD 4650, W7 x64
Re: Splash Lite 1.2
Wed Jan 20, 2010 4:01 am
Memory usage is a bit high in version 1.2. Is this by design?
Watchman
Re: Splash Lite 1.2
Wed Jan 20, 2010 7:37 am
reb0rn wrote:Very nice player :)
Hi reb0rn,
Yes, Subtitles encoding selection will be available in next Splash Lite release (and also some new features).
As for the analog TV cards we are currently not focusing on this as analog terrestial TV is slowly being exchanged to digital.
Best regards.
Watchman
Re: Splash Lite 1.2
Wed Jan 20, 2010 7:43 am
ethaniel wrote:Memory usage is a bit high in version 1.2. Is this by design?
Hello ethaniel and welcome to our forum,
Splash Lite 1.2 uses ~64MB of memory when using GPU accelerated decoding and ~192MB of memory in SW mode (Full HD 1080p/1080i video). As this is not influencing power consumption and is not a high number for modern (even 3+ year old) computers we are not focusing on reducing this number. This is also related with our design and future advanced post-processing algorithms like Motion².
PS. If you see some cases in which this numbers are much greater then please let us know as this would indicate some problem on our side.
Thank you.
bozo
PC Specification: i7 2600k, GF GT240, Win7 x64
Re: Splash Lite 1.2
Thu Jan 21, 2010 8:16 am
Greetings to everyone.
Very nice web and player design. Small and compact. It looks really good.
Below are my suggestion of the improvements to consider:
1. Playlist docking to main player window.
2. An option (maybe in EcoMode menu) which define what player do when finished play of the movie.
for example: A. Close player; B. Shutdown Computer; C. Suspend
the last two options with countdown and cancel button.
3. Information screen: CPU load; current/total_frames and option to show more or basic informations.
4. Subtitles: An option for subtitles without end time to be display with spec time
for example: (time in ms [set by user]) x (each char in current sub line)
as example for "Hello!" word would be 250ms x 6chars so this line will be displayed for 1.5s
problems:
Unable to play wmv movies from link below. There are a lot of VC-1 clips.
Apple H.264 trailers are played without any problems.
