arnulf
Re: Splash Lite 1.4 Remote control
Sat May 22, 2010 5:09 pm
I have a Remote USB receiver that installs as a keyboard.
This works fine in several media players, eg. volume/mute commands is passed to windows and handled there.
But Splash "eat" keyboard commands not used, could commands not used in Splash be be passed to Windows ?
(Play/pause/stop fwd ... works, even in Splash.)
brandx
PC Specification: core 2 duo 3GHz GEForce 8500G XP SP3
Re: Splash Lite 1.4
Sat May 22, 2010 8:19 pm
Very nice. I have several HD Nature videos that look great. I am having a problem with black & white movies. Sound, but no picture. Will Splash play B&W movies? I am an old movie buff and have many movies from the 20s on up.
Thanks
fullhd_fan
PC Specification: Intel E6400, NVidia GForce 7650GS, Vista
Mon May 24, 2010 2:50 pm
One of the Splash Lite 1.4 features sounds like this:
" Numerous GUI, display and stability improvements"
What does this actually mean ? The problems described in my post (highbitrate or/high frame full HD files) are still unsolved. I didn't notice any improvement in this version.
ivansucha
PC Specification: Intel Core2Duo 1,66GHz, GMA950, XP-Home
Re: Splash Lite 1.4 + 1.4.2
Tue May 25, 2010 5:58 pm
Please, can you add again the support for MBT files? As I know, MBT extention is JVC´s version of M2TS, which is generated by Pixela Everio Media Browser HD Edition. There are two ways how to play this kind of file in 1.4 (1.4.2) version:
1. Rename to M2T or M2TS (but the registry of video in Pixela is cancelled)
2. Start Splash, press "Open file", in common dialog change type to "All files" and finnaly select the file (frustrating)
But there is no possibility to double click onto file in windows explorer, even if I set association in windows manually(in 1.3 it worked).
Thank you
Ivan
PS: Thank you for support of playing on extended desktop.
Steve McDonald
PC Specification: AMD quadcore--Nvidia 8500 GT--Vista HP
Splash Lite 1.4.2 Not Working on My XP Computer
Wed May 26, 2010 9:35 am
The 1.4.2 version seems to work fine on my quad-core computer with Vista 32, but when I downloaded it onto my older single-core computer with XP, it will not open. Every time I try to open it directly or instruct the computer to play a certain video with it, I get a pop-up that says "Splash Lite encountered a problem and needs to close".
nhanngoquyen
PC Specification: Core i5 , Geforce 310M , Win7
Sun May 30, 2010 11:13 pm
why Splash Lite don't have Vietnamese language ??? I think it should be have . In Viet Nam , many people use Splash Lite for play video.
Joco1114
Tue Jun 01, 2010 1:08 pm
I thought in the new version I can change subtitle style and/or font. I was wrong. :(
Home Theater:
Synology NAS 1010+ | 9TB HDD
iamyourbrother
PC Specification: Intel Core i5, HD 5730, Windows 7 x64
Fri Jun 04, 2010 7:43 pm
Hello Mirillis team. Splash is crashing everytime i'm trying to open 1080p Video in Splash 1.4.3 what can be wrong?
elvissteinjr
PC Specification: AMD64 2GHz, ATI Radeon HD 4670, Vista 64
Sun Jun 06, 2010 12:00 am
I thought this was impossible. Even you told me that it is impossible. But you made it possible. 1080p MKVs with 6 reference frames running fine after graphics driver update.
Thanks! No other player did this. :D
denleon
PC Specification: amd sempron si-40,radeon hd3200,vista
Sun Jun 06, 2010 10:38 am
elvissteinjr wrote: No other player did this. :D
Really?Try MPC-HC,DivxPlusHD,DaumPot,Nero,which play fine mkv fullhd(16 ref) even with radeon hd3200.Splash not.
