Poko
PC Specification: Intel T5300, Intel 945GM, Win XP SP3
Re: Splash Lite crash on startup
Sun May 29, 2011 8:39 am
I had been successfully using Splash Lite 1.6.1 for several months but just reinstalled Windows XP on my laptop and now I'm having the initialization errors that people had been talking about. I have 2 identical HP laptops, both running Windows XP SP3; Splash Lite 1.6.1 ran fine on both. But since reinstalling Windows XP on one of them, I can't get Splash Lite to work. The Mirillis folders & files in the Application Data and Local Setting\Application Data were missing so I created the folders and copied them from the laptop that Splash Lite is working -- still doesn't work. I tried running Splash Lite Clean Start and it crashes also. It does create the log file and all it has is:
[SplashLog]
CP01=0x0000
CP02=0x0001
I've also tried removing and reinstalling the Microsoft Visual C++ Redistributable but nothing different.
I'm stumped. Any help? I know it's not the hardware or the graphics drivers because both laptops are identical hardware and drivers and OS with same updates, but something about one of them is different and I can't figure out what it is. And the thing is it used to work fine on this one too. Just something different after Windows was reinstalled.
Help!!
d3cK
PC Specification: barton 3200 1,25gb ram, 7300gt
Sun Jun 12, 2011 12:48 pm
A have a similar problem with any version of splash. The program simply don't appears when I'am simply clickin' on it. I dont have any log file. Is this problem is connected with my processor (XP 3200+)? My PC passes minimal requirements of Splash. Please help.
Regards
Tue Jul 05, 2011 10:00 pm
viviannaidoo wrote: ...
"Critical error during initialization"
The application cannot be executed. ERRORS: 0x8009000f, 0x8009000b, 0x8009000f, 0x8009000b,
Hi, all users that experience this problem or similar errors please try the latest 1.9.0 of Splash PRO or Splash PRO EX versions. This versions include some possible fixes for the problem and if this will work then next update of Lite version should also work fine.
Tue Jul 05, 2011 10:01 pm
d3cK wrote:Hi,
Regards
Your CPu probably does not meet requirements, are you sure it supports fully SSE2 instructions?
Poko
Wed Jul 06, 2011 11:42 am
Yes!!! Splash PRO 1.90 works on the computer where Splash Lite 1.61was failing during initialization.
I then reinstalled Splash Lite 1.61 and tried again, and it still has the same failure, while Splash PRO 1.90 continues to work fine.
So the Mirillis Team has solved the problem! I can't wait for you to apply the same fix to Splash Lite!!!!!
Thank you, thank you, thank you, thank you......!!!! :D :D :D
Poko
Mon Aug 15, 2011 11:28 pm
OK, so Splash Pro 1.90 solved my problem but it is for 30 day trial only. It's been over a month since the good news about the fix. When will the fix be applied to Splash Lite and be released for download? I need it! :geek:
Sun Aug 21, 2011 8:06 pm
Hi, we have not specific date for next Lite release yet. It should be avialable within 1-2 months I expect.
