cousin333
PC Specification: X2 6000+, HD3850, Windows 7
Re: Splash PRO 1.12.0 & 1.12.1
Thu Nov 10, 2011 6:09 pm
I have checked many video files for this error, and I have found a dozen one... All of them had DTS soundtrack. While I was doing that, I got the message about the update, so I have installed 1.12.1 and tried it again. I can tell, that the problem seems to be solved with this new version, as none of my test files crashed any more. Thank you very much!
P.J
Thu Nov 10, 2011 11:20 pm
Thanks Ghost, but it's long time we want more features that we wrote in the forum :cry:
BDX
Tue Nov 15, 2011 9:19 pm
What the hell is this Action! anyway? Very dissappointing changelog.
pirotrav
PC Specification: i7 2600k, radeon hd6870, 8gb RAM, win7
Wed Nov 16, 2011 8:11 am
Action! Is a program that records video on the pc, similar to FRAPS. It uses its own proprietary alogirthms, and according to charts here is very light. In defense of mirillis, its a lucrative niche market that there really isn't any decent software for. With Modern Warfare 3, youtube tutorials etc., and everyone wanting to record video, its a growing market. That said, I think its agreed that we all want to see splash get some of the features mentioned before (subtitle improvement/vobsub, chapters on my end for example).
P.J
Fri Nov 25, 2011 11:06 pm
Action! is great but we want more updates for Splash. There're still many issues :(
ertan.kucukoglu
Tue Jan 17, 2012 10:31 pm
I just installed 1.12.1, and got that mentioned crashes on a 1080p movie. My file details are below. Movie starts, and crash comes in a few seconds. I can see a few seconds of the movie. If I click some further location (does not matter how many minutes I pass) I got crash instantly.
As far as I tested, I can tell that no crashes on 720p movies.
General
Complete name : H:\New folder\Trans3 .2011.1080p.BRRiP.x264.Heresiarch-www.divxm.com\Trans3 .2011.1080p.BRRiP.x264.Heresiarch-
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 3.82 GiB
Duration : 2h 34mn
Overall bit rate mode : Variable
Overall bit rate : 3 543 Kbps
Encoded date : UTC 2011-09-29 17:57:20
Tagged date : UTC 2011-09-29 17:57:20
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2h 34mn
Bit rate : 3 000 Kbps
Maximum bit rate : 21.5 Mbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.081
Stream size : 3.24 GiB (85%)
Title : TheFalcon007 @ Transformers 2011
Writing library : x264 core 118 r2085 8a62835
Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=2.00:1.00 / mixed_ref=1 / me_range=46 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-4 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=2 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=15 / intra_refresh=0 / rc_lookahead=80 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=3.9 / qcomp=0.10 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Encoded date : UTC 2011-09-29 02:13:33
Tagged date : UTC 2011-09-29 17:59:27
Material_Duration : 243857
Material_StreamSize : 3476769259
Material_FrameCount : 222097
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2h 34mn
Bit rate mode : Variable
Bit rate : 435 Kbps
Maximum bit rate : 453 Kbps
Channel(s) : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 481 MiB (12%)
Language : English
Encoded date : UTC 2011-09-29 17:59:07
Audio #2
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 34mn
Bit rate : 100.0 Kbps
Maximum bit rate : 108 Kbps
Channel(s) : 2 channels
Stream size : 110 MiB (3%)
Language : English
Encoded date : UTC 2011-09-29 17:59:23
resinate
PC Specification: Win7 Ult
Mon Jan 30, 2012 1:00 am
cant play dobly TrueHD audio format
also player crashes when watching mkv files with ACC audio
nagoli
PC Specification: Phenom2 965, 4Gb DDR2, HD5830, Win7 x64
Mon Apr 16, 2012 7:26 pm
Is the support for Splash PRO discontinued?
It was in it's infancy when I bought it in 2010 nov and no more updates after just a year?
Styvesant
PC Specification: 3570K, 680, 8gb RAM, Windows 7 (x64)
Tue Apr 17, 2012 10:06 am
nagoli wrote:Is the support for Splash PRO discontinued?
The devs said that there will be an update Q2 this year, so no; it has not been discontinued.
EDIT: Actually I am not 100% sure that the update is coming Q2; I thought I read it somewhere. But they are definitely fixing up a couple of things soon-ish.
Splash PRO
vivan
Sat Apr 28, 2012 7:55 pm
Problem - when playing H.264 video with big number of reference frames (e.g. 16) with h/w acceleration on Intel SB GPU's - video have artifacts. But without h/w acceleration - motion2 isn't working. And for lucky people with discrete nvidia GPU's - using them means higher power consumption.
The only decoder that doesn't have this problems - egur's QuickSync decoder. It's under BSD license, so, as I understand, it allows using it commercial programs...
It would be nice if Splash would use it too...
PS Vita, Nokia N8
