P.J
Re: Dark scenes look artificial (video level issue?)
Mon Aug 08, 2011 5:22 pm
kasakka wrote:I really wish you would add the option to set full RGB or limited RGB (16-235) in the software itself. My HDTV does not seem to support full RGB and Nvidia's drivers don't seem to offer an option for this. MPC+ffdshow allows you to set this nicely in software.
I agree with you too. For example in CPU mode, it's more limited than GPU but much less than Overlay which is bad.
Alex
PC Specification: Windows XP
Sun Aug 14, 2011 4:24 pm
"kasakka wrote:I really wish you would add the option to set full RGB or limited RGB (16-235) in the software itself. My HDTV does not seem to support full RGB and Nvidia's drivers don't seem to offer an option for this. MPC+ffdshow allows you to set this nicely in software."
I think this is the best way. Try it.
antorsae
PC Specification: Q6600, Win7x64, ATI 6850
Tue Aug 16, 2011 7:38 am
Hello - I finally had time to take a few shots with my camera to illustrate. My projector (Panasonic AE2000) has something called Waveform monitor which allows you to "see" the video levels of a horizontal line within the screen. This is very handy to quickly see video levels, etc.
In this screenshot
On the left side you see Splash-pro and on the right side you see Media Player Classic HC (MPC-HC). You can see that the video level in the left is offset (see the waveform analyzer on the top of the screen) by 16 and it is OK in MPC-HC.
I've tried different settings:
Ghost wrote:Do you experience the same issues with:
- hw acceleration disabled and motion2 enabled
Same issue:
Ghost wrote: - hw acceleration disabled and motion2 disabled?
Same issue:
The only combination that I get the right levels with is by disabling video overlay:
HOWEVER, eventhough Motion2 is enabled in the configuration settings, Motion2 IS NOT ACTIVE when disabling video overlay so I cannot effectively use Motion2 with the correct (RGB) levels in my setup (ATI 6850 w/ Catalyst 11.6, Windows 7 64-bit ).
NOTE: I've restarted Splash PRO each time I've applied the settings.
gold333
PC Specification: Nvidia GTX275, W764
Tue Aug 16, 2011 11:52 am
antorsae wrote:The only combination that I get the right levels with is by disabling video overlay:
Just to check what you mean, don't you mean enabling video overlay? The default setting for "force video overlay" is unchecked, i.e. off.
P.J
Thu Aug 18, 2011 6:49 am
What about this:
- HW acceleration disabled and Motion2 disabled and Overlay disabled
kushal_fpost
PC Specification: SP2
Sat Aug 20, 2011 5:01 am
I am also having the same issue, please provide me some solution, Thanks..
I am 24, I am male and I love to learn
antorsae
Sat Aug 20, 2011 8:16 pm
I've tested it a bit more:
- Force video overlay checked: No matter what I do, video levels are WRONG.
- Force video overlay UNchecked: Video levels OK, but Motion2 does not work (video is not smooth as it is when Motion2 is working)
Any ideas?
P.J
Sun Aug 21, 2011 9:27 am
Would you upload the video?
Have you tried with and without HW acceleration too?
Thu Sep 15, 2011 9:14 pm
antorsae wrote:I've tested it a bit more:
Any ideas?
Motion2 does not work with force video overlay disabled?
