tuvi123
Re: Splash PRO 1.7.0
Tue Apr 05, 2011 2:17 pm
vsfilter licence is free only for free players, they must write a filter from his own hand
You are wrong, Gabest allow the use of vsfilter also on paid players.
(check out bsplayer for example).
CodeName33
PC Specification: PC1:Athlon620/HD6770,PC2:i3 530/GTS 250
Wed Apr 06, 2011 7:00 am
Hello, I have a question about Splash PRO 1.7.0.
I have tried it on 2 PCs. At work and at home.
Conf1: i3 530 with NVidia GTS 250
Option "Motion2 Ultra 1080p" is disabled in options and can't be checked
Conf2: Athlon II 620 with Nvidia 9800 GTX
Option "Motion2 Ultra 1080p" is enabled in options and checked
on both configurations Split Pro detected hardware acceleration.
I found that some video files can't be played with Picture2 enhancements (like Motion2, Detail boost, etc.) - all this checkboxes are disabled on Athlon's machine. And the same videos playing normally with all Picture2 enhancements on i3 machine.
And there are videos that playing with Picture2 enhancement on both machines.
Can you tell me how Split Pro detects when Picture2 enhancements can be enabled?
hadinba
PC Specification: Intel Core2Duo T8300 @ 2.4Ghz , Win 7
Wed Apr 06, 2011 3:34 pm
version 1.9 does not mean, the next will be v2.0.
after version 1.9 is 1.10, 1.11, 1.12 etc...
Its just the versioning politics.
regards,
plz explain more !!! :o :shock: :o :shock:
Terry
Wed Apr 06, 2011 4:00 pm
nunatak wrote: Yeah, as far as i can see it I'm not going to buy Splash Pro V2...
There hasn't been any real progress since v1.4 but we are already at v1.7... most of the updates should have received much smaller version number. Almost all Stability/features "improvements" are bug fixes and nothing more, no matter how they call it.
Mirillis should focus much more on the other versions and better communication with the customers.
Hmmm... Whats the difference how is it called v.1.4 or v.1.9?
For me the latest updates are quite important. Ultra 1080p is nice. And now BIG improvement for all Broadcom users.
If you dont have a quad core or Broadcom then maybe you can be not satisfied, but I am :twisted:
Terry
Wed Apr 06, 2011 4:03 pm
CodeName33 wrote:Hello, I have a question about Splash PRO 1.7.0.
Hmm ... stop playback, enable best qualy in playback options, should solve your problems :twisted:
CodeName33
Wed Apr 06, 2011 4:40 pm
Terry wrote:Hmm ... stop playback, enable best qualy in playback options, should solve your problems :twisted:
Yes, I can do it (or change options while other video file playin, that hasn't this problems), but this settings are not applying on some files. May be bacause this is not HD content? But the same files play with Picture2 enhancements on other machine. Bug? They shouldn't? :roll:
paradiso_girls
PC Specification: AMD Phenom II X2 Black Edition 550
Wed Apr 06, 2011 5:37 pm
Can append this option to select aspect ratio to 4:3 format monitor is the image, I want to cover the entire monitor.
tony_montana
PC Specification: i7 860@2.80 GHz,HD Radeon 5850,Win 7 x64
Wed Apr 06, 2011 6:40 pm
does anyone know why reusme playback doesnt work for all files. so far it doesnt work on some wmv and some mkv but works on other files with the same container etc.
Edit: nvm it only doesnt save position if the file is not far enough into the video form what i can see.
lucadan
PC Specification: Phenom ii 4x955 nvidia gts 250 seven644c
Wed Apr 06, 2011 8:20 pm
I have tested splash pro on various computer and I noticed that since version 1.5 and later reproduced bad images, showing obvious artifacts on moving images (mkv 1080p). I prefer to use version 1.4.1
Tested with ati, nvidia ,intel gpu and motion2 enabled.
Had you the same experience?
metal005
PC Specification: AMD1090T, HD4870, WinXP 32bit
Sun Apr 10, 2011 1:17 pm
lucadan wrote:I have tested splash pro on various computer and I noticed that since version 1.5 and later reproduced bad images, showing obvious artifacts on moving images (mkv 1080p). I prefer to use version 1.4.1
yes, I have the artifacts with ATI
btw, I only used 1.6 and 1.7, other than the artifacts, the picture quality is much better than purecodec or powerdvd10
also, any improvement of 1.6 and 1.7 over 1.4 and 1.5?
thanks
