Re: April came and went...
Sun Jun 20, 2010 10:41 pm
djohny wrote:Cool! but, is there any official release date?. Thanks!
I keep waiting here your Pro version ^^
We will post info 24h before releasing PRO.
We are goin to release PRO version this week if everything will be allright.
djohny wrote:The light and detail improvementes looks great!, requeriments? my system is: Phenom II 550@B50 quad core at 1,8Ghz (is htpc hehe) with ATI HD 5670, 4GB DDR2 dual channel and win7 64 bit.
I have a lot of hd mkv with DTS audio, is compatible? thanks!
Have a nice weekend ;)
Everything should work well with your PC, mkvs, LightBoost, DetailBoost, Motion2 etc.
djohny
PC Specification: Phenom II 550 + ATI 5670 + 4GB DDR2
Mon Jun 21, 2010 10:19 am
Thanks for your answer! keep waiting here ^^
soulburner
PC Specification: Athlon X2 4850e, 1GB RAM, 780G
Wed Jun 23, 2010 9:09 pm
I am anticipating this software very much and I have a question. My HTPC isn't a powerful machine, it's only an Athlon 4850 with 1GB RAM and 780G integrated graphics. Is there a chance Motion2 will work? At least with 720p video ;)
If not, would some cheap, low power Radeon or GeForce card do the trick with OpenCL/CUDA/Stream?
Thanks in advance!
icsterm
Contact: Yahoo Messenger
Wed Jun 23, 2010 11:14 pm
soulburner wrote:I am anticipating this software very much and I have a question. My HTPC isn't a powerful machine, it's only an Athlon 4850 with 1GB RAM and 780G integrated graphics. Is there a chance Motion2 will work? At least with 720p video ;)
Thanks in advance!
If i'm right 4850 is using the latest Radeon 4xxx technologies so it should fully support hardware accelerated effects/post-effects/shaders. I'm using an 4650 mobility card and it works just nice with DXVA and 4-5 GPU shaders enabled (using MPC-HC).
Streaming HD content is an easy job for most today's modern video cards. As i'm concerned, 4850 card should kick any current game at highest details if powered by a decent CPU. But for HD playback i'm certain 1080p content and Picture2 should be ok.
I don't consider 4850 an HTPC card because of the high power consumption. Best HTPC card nowadays i consider a passively cooled one, especially ATI 56xx series because of the fair price.
Before testing anything make sure you are using updated Catalyst drivers.
soulburner
Thu Jun 24, 2010 10:49 am
The 4850 I'm talking about is the processor's name ;) Athlon 4850e (2500MHz, Brisbane core), to be exact, so sorry for the confusion. I don't think the integrated 780G graphics is really capable of performing anything more than DXVA ;)
icsterm
Thu Jun 24, 2010 10:55 am
soulburner wrote:The 4850 I'm talking about is the processor's name ;) Athlon 4850e (2500MHz, Brisbane core), to be exact, so sorry for the confusion. I don't think the integrated 780G graphics is really capable of performing anything more than DXVA ;)
Sorry for the awfull mistake.
If it's an one core processor i doubt it will handle 1080p, but 720p should work out, but with Picture2 disabled unfortunately. I also think these post-effects are GPU accelerated, and the integrated won't run them.
You should consider upgrading.
soulburner
Thu Jun 24, 2010 11:10 am
It's dual core and handles 1080p flawlessly, especially with DXVA enabled. So I was wondering if Motion2 could work at least with 720p video. I will experiment later today and see if the integrated graphics can do any OpenCL :P
icsterm
Thu Jun 24, 2010 4:09 pm
soulburner wrote:It's dual core and handles 1080p flawlessly, especially with DXVA enabled. So I was wondering if Motion2 could work at least with 720p video. I will experiment later today and see if the integrated graphics can do any OpenCL :P
You can test the PRO version beggining tomorrow. 8-)
UK_Greg
PC Specification: T9600 Radion HD 4650 windows 7
Sun Jun 27, 2010 1:24 pm
Well - I just bought my Pro version :D
Not tested it thoroughly - however - id doesnt play some Avi files that work on real player :(
