Like Ghost already told us, it's out of their hands....it depends on other companies...alexvasile wrote:I think ..... (maybe) next year![]()
...am tired to wait . i demand a straight answer
thanks , i'm waitlatino wrote:Like Ghost already told us, it's out of their hands....it depends on other companies...alexvasile wrote:I think ..... (maybe) next year![]()
Hi!sleezie wrote: ...
Now to my question:
-Do you have any plans to implement more functions into Splash pro as example something along the lines of "True Theater lighting"? What this function does is to correct chroma/luminance and colour on the fly and the results are quite spectacular on my LG 47LH3000.
I think it would be great to be able to tweak the picture quality a little more than is possible through the Ati Catalyst.
Thank you for the most promising media player as far as I'm concerned and good luck with sorting out your licensing problems!!
Sounds great! I take it that these functions will have "sliders" of some sort to make it able to tweak the picture with greater granularity?Ghost wrote:Hi!sleezie wrote: ...
Now to my question:
http://mirillis.com/picture2.html
Light Boost should be an answer for your question.
Picture2 will initially include:
Motion2
Light Boost
Detail Boost
All this technologies will be available for SD/HD content and with H/w acceleration enabled and disabled
All Windows versions (XP.Vista.7) supported.
crl2007 wrote: I believe that ATI introduced this in their drivers for the 5xxx series.
