creative
PC Specification: i5 ATI 5870 Win7 64
Re: Splash PRO 1.7.0
Tue Apr 19, 2011 7:07 pm
My topic hasn't been approved after 4 days so I'm posting my question here for Splash Pro 1.7:
Is it possible to use the HD Camcorder's GUI for AVCHD folders copied from my camcorder to the hard drive. As of now, when clicking on HD Camcorder, Splash Pro looks for an attached camcorder. I'm hoping to direct it to an AVCHD folder on my hard drive so I can use it's elegant GUI to view movies.
hln
PC Specification: MacBook Pro, thunderbolt, ZBox AD03 HTPC
Fri Apr 22, 2011 1:42 pm
Love Splash Pro and Ex for use with MediaBrowser
demonizator
PC Specification: Core 2 Duo, Radeon HD 5700, Windows 7
Fri May 06, 2011 5:58 pm
I'm having some problems with the "automatically open next file" option. Regardless of any setting my Splash PRO won't automatically play the next file in the selected folder nor the next file in any playlist. Please advice!
:cry:
Re: Splash PRO 1.7.0 & 1.7.1
Fri May 13, 2011 6:55 pm
Splash PRO 1.7.1 is available.
What's new in Splash PRO 1.7.1?
* MPEG-1 video playback improvements
* Stereo audio playback on 5.1 analog output fixed
* Command line improvements
* Subtitles encoding selection added
* GUI and stability improvements
Fri May 13, 2011 6:56 pm
creative wrote:My topic hasn't been approved after 4 days so I'm posting my question here for Splash Pro 1.7:
Not yet, but we plan to add this in the future.
This will be avialable only for AVCHD structures that does not contain any menu.
demonizator wrote:I'm having some problems with the "automatically open next file" option. Regardless of any setting my Splash PRO won't automatically play the next file in the selected folder nor the next file in any playlist. Please advice!
:cry:
Whats happening after finished playback?
If it is playing again the same file please make sure to disable loop option.
lbamda
Sat May 14, 2011 9:54 am
Ghost wrote:Splash PRO 1.7.1 is available.
Has passed one and a half month and it is all that has been made? WHEN serious problems will be solved?
I remind :
1) After version 1.5.0 exit till now doesn't work hardware deinterlacing on 60i source on radeon video card;
2) Not support 'ASS' and 'SUB' (from DVD) Subtitles;
3) On subtitles 'PGS' it is not displayed more than two lines;
4) On the menu opening by the right button of the mouse, doesn't work keyboard (arrows) - it is impossible to use remote controls;
5) Not support chapter in mkv;
6) Not support name track in mkv (support only track language).
7) Not support 4.0 (quadro) audio setup.
8) If audiotrack in mkv video file only one and it LPCM, it isn't play (silence) - is highlighted by red color. If it audiotrack compulsorily to choose, player under abnormal finishes work with an error.
metal005
PC Specification: AMD1090T, HD4870, WinXP 32bit
Sun May 15, 2011 9:00 pm
metal005 wrote:
I actually got a 1090T into my MB, but Splash Pro crashed, showing error message about "memory cannot be read" something like that
It also happened on purecodec, so it's a hardware problem, probably culprit is the beta bios of my AM2+ MB
didn't have AM3 MB on hand though
okay, installed win7, worked very well, not bios problem but seems like WinXP and AMD 6-core have some incompatibily, as also advised by local AMD agent
cpu usage go down frm 40~60% in 965 to 30~40% in 1090T
razor
PC Specification: ATOM D525, ION2 4x, 2GB
Thu May 19, 2011 12:36 pm
Which are "Command line improvements" in Pro 1.7.1 ?
amhsby
PC Specification: I5 2.4 GHz,NvidiaGT330M,OS7HP,ram 4GB
Tue May 24, 2011 8:09 pm
in the future, can splashpro added video format extensions .tp
coz my MV n PV korean pop with .tp extensions
i like your detail n light boost
i hope this extensions .tp works for the next splashpro version
dmitry4er
PC Specification: Intel Corei7-860, Nvidia GTX460, Win7x64
Wed May 25, 2011 8:13 am
Are you planning to support 3d in this player? It would be nice to see 3d files (at least stereo pairs - OverUnder and SideBySide) on 3dtv. Today i can do it with some other media players, but all of them works so slowly (in different to this one)...
