Joco1114
Re: Splash PRO 1.2.1 & 1.2.2 & 1.2.3
Fri Oct 01, 2010 9:09 pm
Thank you guys, now the FullHD playing on nVidia is working correctly and smootly.
I will report bugs tomorrow.
Good night!
Home Theater:
Synology NAS 1010+ | 9TB HDD
nenco
PC Specification: Core i7, HD5730, 7 64bit
Fri Oct 01, 2010 10:06 pm
problem solved with avi files, now it stop playng when program close
ashap
PC Specification: Intel Core i5,nvidia 275,Windows 7 x64
Sat Oct 02, 2010 3:16 pm
please add support to remember file position
resinate
PC Specification: Win7 Ult
Sun Oct 03, 2010 8:43 pm
about dam time this software is finally worth every dime i put into good job guys.!!!
Ralf
PC Specification: Intel E6850, Nvidia GTX 260, Win7 64 Bit
Mon Oct 04, 2010 5:29 pm
Splash PRO 1.2.3 work much better on big HD files with nvidia GPU, thank you Mirillis! :)
tony_montana
PC Specification: i7 860@2.80 GHz,HD Radeon 5850,Win 7 x64
Mon Oct 04, 2010 6:03 pm
ashap wrote:please add support to remember file position
yeah please add support for Remembering File Position. also some Pan&Scan options would be very nice.
Joco1114
Wed Oct 06, 2010 5:40 pm
I have a file named 99999.m2ts in my Splash Pro folder. It contain six frames on the screen.
What is that?
Home Theater:
tony_montana
Thu Oct 07, 2010 3:11 am
Joco1114 wrote:I have a file named 99999.m2ts in my Splash Pro folder. It contain six frames on the screen.
What is that?
:? great bug report lol
Joco1114
Thu Oct 07, 2010 4:46 am
What is that?
You didnt catch that. This file is located in the Splash Pro folder and it seems it comes with the installer itself. Maybe it is a future upgrade (a menu for home theaters?)... It is NOT a bug report, just a question. Do you know the answer? :|
Home Theater:
Fri Oct 08, 2010 6:48 pm
What is that?
Hehe, this is a HD camcorder interactive menu background.
If you plugin avchd camcorder to your pc than you can browse clips using thumbnails.
http://mirillis.com/gfx/splash_pro/spla ... r_menu.jpg
