what is the source of the variable fps files: is it a dump from TV, your own remux (join) of few files? what is the container of the files. Did you mean application or system reboot?vivan wrote: Problem with variable fps. Sometimes when video has e.g. 24 fps than 60 fps...
But after reboot everything turns to normal.
In next update we will include some possible fix for this. Will get back here when 1.3.3 is released and will provide you with further instructions/info.EvertonMonkey wrote:Any news on the problems with Intel HD Graphics problem that at least 3 of us on here are having ?
We can repeat problem, will be fixed in 1.3.3.Joco1114 wrote: Thank you, I will check it. Alt+F4: if you cannot repeat this problem, maybe the problem is in my hardware. Interesting: I've tried with my remote and with keyboard. Not all the time, but 2-3x of 10 I cant close... No other windows, just a simple Win7 x86 Pro with SP1 RC1. It's not a big deal, after an Enter (back to normal size) I can close.
Tomorrow or next week. Depends on Quality Control tests results.Skywalker wrote:I can`t wait for the next version of Splash Pro with the option to display subtitles outside of video !
Can anyone from Mirillis team to give us an update about the possible date when the next version will be released ?
Seems to work ok for me. Thanks.Ghost wrote:Joco1114: alt+f4 problem, and problem with running files with doubleclick on mltidisplay setup should be fixed now
Intel52: ctrl+o, and problem with hidden mouse cursor should be fxed now in Splash PRO 1.3.3
EmZvr, EvertonMonkey, abejan: Please try the latest 1.3.3 version. Open Playack Options panel and make sure all Basic Video Controls are set to 0. Please confirm if it works on your PCs.
