Splash PRO 1.13.0 - 1.13.2
Mon Aug 27, 2012 6:45 pm
We are happy to inform that Splash PRO 1.13.0 is now available for download
including important improvements for Windows 8.
Chanelog:
* IMPORTANT: Full support for Windows 8 added
* Playback of AVI files with FICV video added (support for Mirillis Action! video recordings playback in AVI file format)
* H.264/AVC software video decoding improvements
* LPCM audio decoding improvements
* MKV stability improvements
* Srt subtitles improvements
* Stability improvements
* Multi-language installer added
As this version introduces new installer we recommend to uninstall older versions before installing Splash PRO 1.13.0.
P.J
Re: Splash PRO 1.13.0
Tue Aug 28, 2012 3:12 am
Thank you, but there're still so many bugs in the forum :(
Styvesant
PC Specification: 3570K, 680, 8gb RAM, Windows 7 (x64)
Tue Aug 28, 2012 10:33 pm
Baby steps, P.J. :)
Splash PRO
BHZGAME
PC Specification: Core i7-2630QM-GeForce GT 540M-W7 SP1
Wed Aug 29, 2012 1:07 pm
Thanks Guys!! :mrgreen: :mrgreen: I've been waiting for this!!! :P :P :P :P
Splash viewer
PC Specification: hp quad win 7 ultimate
Wed Aug 29, 2012 1:32 pm
Found a little bug in 1.13.0
When saving a still capture from a dvd (mpeg2) file which has the 16:9 marker set (widescreen)
The saved image is 720x(480,576) 4:3 instead of 1024x(480,576) 16:9
Splash viewer
Wed Aug 29, 2012 11:27 pm
Found a OLD bug still present.
By creating a play-list of several movie's when the player goes to the next movie, the time is stopped and the arrow key does not function anymore, to get rid of this en activate the timer again, i must skip a movie by page-down.
The time is stuck at the length from the last movie played.
This is a bug present from + -1.9.0
i have posted before about this.
denon480
PC Specification: Core i5 2500k, HD6970 Windows 7
Thu Aug 30, 2012 9:04 am
Hi all i have a question,whether it is possible as that to change a command key if there is no that tell please when there will be such function. Especially interests to appoint volume control to the keyboard.
Splash viewer
Thu Aug 30, 2012 12:21 pm
Splash viewer wrote:Found a OLD bug still present.
Yes if some more testing done about this bug
If i unset this
The bug disappears but the setting is ignored and the player goes to the next file.
With this setting, the time bug appears again.
Splash viewer
Thu Aug 30, 2012 1:57 pm
If i unset this
Another update about the time bug, i can now repeat the bug when ever i want. :D :shock:
Its really simple.
Put a playlist together:
Computer pseudo code:
Code: Select all
go with arrow keys to the end till the time no longer updates
Let the player auto advance to the next file
if file == shorter then arrow keys are disabled and the counter stand still
you can manually  skip a file or go back the counter still freezes. Its completely frozen.
How can i to make the counter working again and also the arrow keys?
goto a movie witch is longer then the file you have friezed with the arrow keys press left or right and everithing is oke!
goto a new file: press right to the end, let the player advance to the next file and the counter freezes again.
Goto a longer clip and etc etc etc
Before post i tested it again and the bug is still repeatable.
I am not sure if the setting play the next file is something to with it, but this function is not working anyhow.
The player goes always to the next file, regardless the setting.
denon480
Sun Sep 02, 2012 10:05 am
denon480 wrote:Hi all i have a question,whether it is possible as that to change a command key if there is no that tell please when there will be such function. Especially interests to appoint volume control to the keyboard.
Is anybody here?
