Splash PRO EX 1.13.0 & 1.13.1
Mon Aug 27, 2012 6:46 pm
We are happy to inform that Splash PRO EX 1.13.0 is now available for download
including important improvements for Windows 8.
http://mirillis.com/en/products/splashexport.html
Chanelog:
* IMPORTANT: Full support for Windows 8 added
* Playback of AVI files with FICV video added (support for Mirillis Action! video recordings playback in AVI file format)
* Fixed problem with cut/corrupted exported MP4 videos (low disk space protection)
* Not starting export (showing 0% progress) problem fixed
* H.264/AVC software video decoding improvements
* LPCM audio decoding improvements
* MKV stability improvements
* Srt subtitles improvements
* Stability improvements
* Multi-language installer added
As this version introduces new installer we recommend to uninstall older versions before installing Splash PRO EX 1.13.0.
juanlola
PC Specification: core i5, nvidia 9800gtx+, windows 7 x64
Re: Splash PRO EX 1.13.0
Tue Aug 28, 2012 1:33 am
Thank you, this version is most stable in windows 8.
But.... i still having problems with some videos .WMV FullHD. Please fix this problem
alexdonwarez
PC Specification: Core i5 Gfx 240gt Windows 8
Wed Aug 29, 2012 6:54 am
I have a installed Splash PRO EX 1.13.0 on Windows 8 today. Everything went good, but i had a problem with subtitles. When i load subtitles in it, it has black background. I think it creates 2 layers to do that. BTW i dont have problem on other player such as SPlayer, MPC, Gom Player and even Media Player.
I tried everything, installed drivers unintalled drivers, installing other versions of drivers, motion and othe options off and on, subtitle options, Gpu decoding on off etc.. i think the subtitles problem still exists in the latest version also..please see to it...
DVDRanger
PC Specification: Win7-8 ( 9 pc's- 6 laptops- 1 tablet]
Thu Aug 30, 2012 10:32 pm
How about adding a Check for Updates in the Settings this would be a great help !!
gdavidoff
PC Specification: WINDOWS 8 PRO X64
Mon Sep 03, 2012 11:27 am
@alexdonwarez
gdavidoff wrote:
Bazikcho wrote:Try disable "Force video overlay" in video setings.
I try 1.12.1 in win8 preview but this options was disabled now with 1.13 maybe it work.
It works!!! Thank you. ;) ;)
loraine57
PC Specification: windows 7
Mon Sep 03, 2012 2:38 pm
Hello
I install Splash PRO EX 1.13.0
I seen when making a fast forward movie
its bug slpash PROEX secce run
  Windows 7 64 bit.
  the file is dvdrip. avi
Wed Sep 05, 2012 10:22 am
loraine57 wrote:Hello
  Windows 7 64 bit.
Is Splash PRO EX application not responding?
loraine57
Fri Sep 07, 2012 5:29 pm
Windows opens a window with mark
Splash PRO EX has stopped working windows search error
then 2 minutes after windows will close the program because it responds more
Visigoth
PC Specification: C2D @ 2.13 GHz, 2GB, W7 x64, NVIDIA G210
Wed Sep 12, 2012 9:31 pm
Guys,
There is a pretty nasty memory leak when playing large .mkv files (Blu-ray quality) after about half an hour with the latest Splash Pro EX. I will try to get a screenshot of it. This is on a Lenovo Z380, Windows 7 Pro x64, Intel Core i5 3210M 2.5 GHz, 8 GB RAM, latest updates for everything (including latest driver for HD4000, version 8.15.10.2761). :(
Re: Splash PRO EX 1.13.0 & 1.13.1
Tue Dec 04, 2012 5:56 pm
New Splash PRO EX 1.13.1 is now available.
Full change list:
* Improved video exporting performance
* Fixed video seeking with hardware acceleration enabled for some graphics card models
* Improvements for video playback for Windows 8
* Minor Motion2 improvements
* Translations improvements
* Added Brazilian Portuguese translations
