You're right. I see now: m2ts, mts, m2t, mpg, ts, trp, mp4, m4v, m4a, mov, avi, vob, mkx, divx, asf, wmv, mp3, mp2, aac, ogg, flac.vivan wrote:FLAC & Ogg are already supported...
For xvid/dvix splash is using system decoders.
You wouldn't believe...Gunhed wrote:I honestly can't work out what the external video processor manufacturers are waiting for ? Thank goodness for splash pro providing a software solution.
This will be added in the next Splash PRO version (1.7.1 or 1.8.0).ala1402 wrote:Enable arabic subtitles please for Arabic viewers and customers
We plan to add this but not in this Splash PRO version.insect000 wrote:How about adding support for FLV? the VP* codecs (vp6, vp7, etc...).
We have this included in our long term plans but as this is not widely used I do not expect it to be supported soon.Gunhed wrote:Dear Team Mirillis,
Is there any chance of support for the Enhanced VOB container as used by HDDVD ?
Yes two AVI files may contain a video in different formats (In example H.264, DV, Motion JPEG etc).suzaane wrote:Whats the difference between codec and media file format? i'm quite confused, is it like an .avi file is encoded in different formats? meaning, two .avi files with different codec requirements wont play in a system that support only 1 type of the 2 codecs? or is a media file format encoded in only one type of codec?
