Mirillis proprietary audio and video codecs
Fri Dec 11, 2009 3:38 pm
Mirillis proprietary audio codecs:
* AC-3
* AAC LC
* HE-AAC (AAC Plus)
* LPCM
* ADPCM
* DTS
Mirillis proprietary video codecs:
* MPEG-4 AVC/H.264
* MPEG-2
Under development:
* E-AC3 audio decoder
* SMPTE VC-1 video decoder
* Partial hardware H.264 decoding (on ATI X1250+ and nVidia 7xxx series)
DGMurdockIII
PC Specification: AMD Phenom, ATI Radeon HD 4600 Win764bit
Re: Mirillis proprietary audio and video codecs
Fri Mar 12, 2010 7:34 pm
is the codec avable to use in other media type project that need support for these
Sun Mar 14, 2010 9:36 pm
DGMurdockIII wrote:is the codec avable to use in other media type project that need support for these
At the moment our codecs are not available for other software as filters/plugins.
This option is still being considered.
Morien
Tue Mar 23, 2010 2:55 pm
I hope you do allow your codecs to be used in other players as filters or plugins. The h264 dxva filter works perfectly for me, however the sound in many of my files don't seem to work with Splash :(
Thu Mar 25, 2010 10:05 pm
Morien wrote:I hope you do allow your codecs to be used in other players as filters or plugins. The h264 dxva filter works perfectly for me, however the sound in many of my files don't seem to work with Splash :(
Please open Splash info panel (press "i") and check what audio format is detected. We are planning to add more audio codecs soon. We are not planning to release our codecs as filters or plugins in the near future, but we consider it for long term future plans.
user82
PC Specification: Q6600,Ati HD-4850
Fri Apr 30, 2010 1:43 pm
Hi!
MPC-HC some time ago added DXVA for ATI-cards for H264 with High@L5.1 and too many Re-Frames(i tested 1080p with 9ref and 720p with 10 ref)
would be a big advantage in your player!
Greetings
user
ps: i did not fully understand the technical details but i think the new Catalyst made it easier
Wed May 05, 2010 7:27 pm
user82 wrote:Hi!
Greetings
user
Hi, we are going to check it soon.
noviegoer
PC Specification: Pentium4,ASUS EAH 4650,WindowsXP2Pro
Sun May 23, 2010 1:40 pm
When Vorbis Audio Codec will be add :?:
Mon May 24, 2010 9:08 pm
noviegoer wrote:When Vorbis Audio Codec will be add :?:
I think it should be availble with next release after Splash Lite 1.4.1.
icsterm
Contact: Yahoo Messenger
Mon Jul 26, 2010 2:29 pm
no news about FLAC yet?
Return to “Mirillis Codecs”
