ocd
Re: 24 Bugs and Enhancements
Fri Aug 26, 2011 10:33 pm
I came upon this thread and even though you have good intentions vladax, you are better off re-designing MPC-HC or GOM or VLC.
Yes, Splash needs work. But the reason so many of us like it is for its SIMPLICITY. That's right. Sure I can easily use MPC-HC or XBMC, or GOM, or VLC, or plethora of other software, but Splash has its cleanliness.
Splash is a NO B.S. to the point player. It has its flaws, but a product is not better because of FEATURES, its better because of how well it implements the BASIC features.
Instead of polluting SPLASH interface and Front End, I think there should be a Seperate ADVANCED Functions and Features program that should be given that will allow the use of More Settings.
This way, BASIC Splash Pro will be there, and if an advanced user wants, they can use a secondary executable file which will allow changes to be made to Backend features that you mentioned, like subtitle handling, etc etc.
This however is probably a long way to go. I am sure the SPlash team is focused more on Fixing and bettering what they already have than to think about adding more Problems to their product.
The more features, the more Bugs and Problems. Its better to remain Simple. When you have a good product that works, you stick to making it better, not adding more and more junk.
P.J
Mon Aug 29, 2011 8:01 pm
qwerty wrote:Yes, I can change option, but resize 2 16:9 format - splash don't keep original aspect ratio.
Here is sample (I cut audio): http://www.mirrorcreator.com/files/1NSS ... .avi_links
It works fine for me, True 1.667. I've also installed no DivX/XviD codec.
Can you take a screenshot? :?
qwerty
Tue Aug 30, 2011 10:45 am
Original files is compressed x.264 and have the same problem (so this is not codec problem). Screenshot:
No keeps aspect ratio.
P.J
Tue Aug 30, 2011 7:31 pm
Strange. It's correct for me :?
Do you have the latest version?
qwerty
Thu Sep 01, 2011 9:34 am
Check splash lite 1.6.1.
Splash Pro 1.11.0.0 works fine.
P.J
Fri Sep 02, 2011 8:28 am
They didn't still release any update for Lite version.
That's why we're working on Pro/Pro EX version.
Thu Sep 15, 2011 8:20 pm
qwerty wrote:Check splash lite 1.6.1.
This should be fixed with next update of Lite version. We expect it to be available in 1-2 months.
qwerty
Fri Sep 16, 2011 11:00 am
Fix some subtitles problem. I have mkv file and this file have 19 subtitle track. Here is sample:
http://www.mirrorcreator.com/files/CHG3 ... .mkv_links
Splash lite and pro doesn't show any available subtitle track.
ocd
Fri Sep 30, 2011 10:55 am
Subtitle Issue here as well.
Got Serenity English translation to Chinese/Russian, converted it into UTF-8, TV plays it, Splash loads its but doesn't show anything on screen. Very weird. Its all standard. But No show.
P.J
Sat Oct 01, 2011 11:00 pm
qwerty wrote:Fix some subtitles problem. I have mkv file and this file have 19 subtitle track. Here is sample:
tsMuxeR can't detect subtitles too :?
Return to “General Topics”
