MaksFearless
PC Specification: ----
The problem in nvidia drivers 285.62
Wed Nov 16, 2011 12:31 pm
Now Splash Pro Ex player problem in fullscreen with the video card nvidia GT430 is on the new drivers 285.62-desktop-win7-winvista-64bit-international-whql.exe. Video so slow in full screen mode. After many tests it turned out that the problem is the player with video card drivers. Fix please.
P.J
Re: The problem in nvidia drivers 285.62
Fri Nov 18, 2011 10:26 pm
Try to install the previous driver then reboot and check the result again.
It's worth to check this too: http://forum.doom9.org/showthread.php?t=161506
MaksFearless
Sat Nov 19, 2011 10:02 pm
exactly the same problem you have, as my problem
that helped to solve this problem??
I've tried it. Not anymore. To older drivers (a year ago) will not pass in principle.
P.J
Mon Nov 21, 2011 12:55 pm
I even contacted Nvidia but no use. So it's not Splash issue :?
MaksFearless
Tue Nov 22, 2011 2:09 am
I recorded with the help of "Action!" this problem and posted on you-tube
http://www.youtube.com/watch?v=rGr9z93_Iu0 WATCH
Video constantly slowing FPS = 8-10 when setting Deinterlacing (Auto)
If you select "Disable Deinterlacing" - no problem, FPS = normal
This problem is not Nvidia, this is a problem - Splash Pro, because it loses PowerDVD11 any video format. TS without problems!
The characteristics of the video being played:
General
Complete name : D:\Видео\Спорт\2011-12_LaLiga_R13_sev-atl_RGfootball_HD\time 1.ts
Format : MPEG-TS
File size : 5.05 GiB
Duration : 51mn 11s
Overall bit rate : 14.1 Mbps
Video
Menu ID : 12102 (0x2F46)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=64
Codec ID : 27
Duration : 51mn 11s
Bit rate : 13.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.250
Stream size : 4.64 GiB (92%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 6
Duration : 51mn 11s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 3ms
Stream size : 164 MiB (3%)
Language : Russian
Language, more info : Clean effects
aviwil
Tue Nov 22, 2011 8:47 am
Maksfearless - I think this is a Splash problem .
De-interlacing is not significant by me .
When playing GPU-Z starts at 20% load ( as expected ) and after a few seconds goes up to about 70% and stays there - with other media players , I don't get that .
MaksFearless
Tue Nov 22, 2011 11:29 am
In PowerDVD also has Deinterlacing option, but there is no problem with the file format. TS (MPEG2), but other players with no Deinterlacing also no problem, so that this problem only occurs in Splash Pro, Tested many times.
P.J
Fri Nov 25, 2011 5:52 pm
Please take a screenshot with GPU-Z's Sensors tab while playing it.
MaksFearless
Sat Nov 26, 2011 5:42 pm
Why do you have screenshots GPUZ??? It has no relation to this issue. If you think that the problem in my computer, then you are mistaken. I fixed this problem in different configurations of Hard, including on their own, in other words - at all.
P.J
Sat Dec 03, 2011 7:32 pm
I know it's not your problem but that might help mirillis team.
Return to “General Topics”
