No audio & crashes when recording is stopped.
Posted: Tue Feb 18, 2020 7:40 pm
by TheMountainMAN
Hello, I seemed to be experiencing a bit of a problem. Action! is not picking up any microphone audio or game audio at all. And when I end the recording the whole the thing just crashes. But when you bring it back up, the video file is broken. I have never had this happen to me so I'm not sure what to do.
I looked at my drivers and none of them were displaying any kind of problem that I could see. But when I checked the DxDiag I found:
Fault bucket 1565619206175907368, type 5
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: Action.exe
P2: 4.1.2.0
P3: 5e407be8
P4: cfe9
P5: 134234112
Re: No audio & crashes when recording is stopped.
Posted: Wed Feb 19, 2020 7:16 am
by Piotr
please provide us your PC DxDiag report. It will help us investigate your problem.
Click on, "Start Button".
Click on, "Run".
Posted: Wed Feb 19, 2020 11:52 am
by TheMountainMAN
Well I guess that's another problem, It won't take the DxDiag file at all. It says its a invalid file extension.
Posted: Wed Feb 19, 2020 12:25 pm
by TheMountainMAN
If there is something specific from the DxDiag then I can copy and paste it, but it wont let me attach the file.
Posted: Thu Feb 20, 2020 7:11 am
by Piotr
TheMountainMAN wrote: ↑Wed Feb 19, 2020 12:25 pm
Change file extension to .zip and attach it to your post.
Posted: Thu Feb 20, 2020 11:32 am
by TheMountainMAN
Alright here you go.
Posted: Wed Feb 26, 2020 7:36 pm
by TheMountainMAN
So can it be fixed?
Posted: Thu Feb 27, 2020 7:13 am
by Piotr
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
6. Install Action! again. Make sure that your installer file comes from official website -
www.mirillis.com (if you have not purchased Action! through Steam).
Posted: Fri Feb 28, 2020 3:48 am
by TheMountainMAN
That worked! Thank you so much for the help I really appreciate it.
