Claunator
Re: Users' Wishlist
Tue Nov 11, 2014 9:39 am
bmcfarl wrote:2) A more user-friendly folder navigation. It seems to take a lot of steps to find the folder that you want to store the recording in. For instance, the user's "Desktop" folder is not easily available. You have to navigate to c:\users, then c:\users\xxxxx, and finally c:\users\xxxxx\desktop.
It's not that hard, it's just a matter of getting used to.'
Buffometer wrote:Add option to use additional lossless codecs(they must be installed in the system).
1.Ut Video Codec Suite http://www.videohelp.com/tools/Ut-Video-Codec-Suite
2.MagicYUV http://magicyuv.com
This is actually better than my suggestion of using numerous other codecs.
Buffometer
Contact: ICQ
Re: Users' Wishlist
Mon Nov 17, 2014 11:39 pm
Maybe this topic is worth to attach to the top?.
Just a suggestion.
Claunator
Re: Users' Wishlist
Tue Nov 18, 2014 4:36 pm
Buffometer wrote:Maybe this topic is worth to attach to the top?
I asked for that in the initial post. I believe it needs to be done, but it's up to Mirillis to decide.
Yin Cognito
PC Specification: i3-2350M, AMD HD 7610M, Windows 7 x64
Re: Users' Wishlist
Wed Nov 19, 2014 1:09 pm
Only one wish :
Automatically switch between Game Mode (DirectX/OpenGL) and Active Screen (Desktop) Mode, depending on the active mode when recording.
For example, I set up Action! for game recording, but it would be nice if the software would switch to desktop recording if I press the F9 button when "in Windows" without me having to manually switch the recording mode.
Re: Users' Wishlist
Wed Nov 19, 2014 1:29 pm
Yin Cognito wrote:Only one wish :
Screen Mode do this.
Yin Cognito
Re: Users' Wishlist
Wed Nov 19, 2014 2:41 pm
You're right, thank you.
But when closing Fifa 09 while recording, a "Fifa 09 stopped working" message shows up. I know the "normal" procedure would be to stop recording and only after that to close the game, but I'm wondering if this is OK. It doesn't bother me too much (after all, the game application closes anyway), but still...
Here's the log :
Problem signature:
Problem Event Name: APPCRASH
Application Name: FIFA09.exe
Application Version: 0.0.0.0
Application Timestamp: 48c5b1ac
Fault Module Name: atiumdva.dll
Fault Module Version: 8.14.10.342
Fault Module Timestamp: 4f1929d4
Exception Code: c0000005
Exception Offset: 00001535
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1048
Additional Information 1: c198
Additional Information 2: c1985e73a505063c8f3b6d3f69838b17
Additional Information 3: 0625
Additional Information 4: 0625fd5aa9df12882862edb43246c17a
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Hope this helps.
Thank you again for the solution you posted earlier.
P.S. The recording process and the resulting video file are not affected by this.
Re: Users' Wishlist
Fri Nov 21, 2014 11:10 am
It seems that the faulty module is atiumdva.dll. I would start with SFC scann on your PC to see if there are any missing or broken files.
Kratzigel
PC Specification: AMD 2 FX 6300, Win 10, GTX 750TI
Contact: Twitter YouTube
Re: Users' Wishlist
Tue Nov 25, 2014 9:50 am
Hello all,
first, sorry for my bad english i hope you can understand it. ;)
So my wishes obtains the upload modul via youtube.
okay let it start it!
1. Youtube Tags
In the currently version of action can't we not writing the tags into the youtube video, when we it uploading the actually file to the account, than we must be editing the tags in the videomanager on youtube.
2. Youtube Thumbs
What i here want is, that we can uploading a thumbnail picture from the pc into the actually uploading file.
Maxi Resolution 1280x720px and max size 2 Megabite.
3. Youtube Description
Actually is the field for the description in action a little bit buzzy, than we can only a certain of words typing into this field.
I wish we can in the future better typing longer text in this field expand. Screenshot under this text.
I Hope u can try this into the next version of action.
Thank you for participation!
Grets Kratzigel
trooph
PC Specification: i5 4670k@4.2 16gb ddr3 r9 280x win7 64bi
Re: Users' Wishlist
Sat Nov 29, 2014 3:24 pm
Choosing audio sources or some way of adding teamspeak skype vetrillo and other audio sources to record in another audio track.
This would be neat but i do get that it might be impossible or very hard to achieve
Wygn
PC Specification: I5 3570k, 6950 1gb, 8gb ram, Windows 7
Re: Users' Wishlist
Sat Nov 29, 2014 10:32 pm
We really need higher higher bitrates for intel quick sync, games with lot of grass look absolutely terrible (like dayz or arma 3 for example, probably GTA V as well when it comes out).
I know you said it's optimized for maximum performance, but come on, put it in just as an option (somewhere hidden in advanced settings at least, to use at our own risk).
