Action! 1.1.0
Sat Nov 19, 2011 11:06 am
Action! 1.1.0 is now available:
http://www.mirillis.com/en/products/action.html
Changes:
* Fixed recording of 10 bits per color DirectX 10/11 gameplay (i.e. DiRT3)
* Real-time sound recording in MP4 audio format (M4A) added
* Improved raw FIC recording playback on 1366x768 display devices (video image was not sharp)
* Added option to disable/enable individual Action! hotkeys
* New hotkey ("S") to switch "Snap to windows" On/Off in desktop region recording mode
* Action! player stability fixes
* GUI improvements
icsterm
Contact: Yahoo Messenger
Re: Action! 1.1.0
Sat Nov 19, 2011 1:35 pm
I confirm quality(clarity) has increased on 1366x768. Now the recording is perfect.
Good job.
Now maybe you can add JPG compression setting for captures, and MP4 audio bitrate setting.
Also add option to hide tray icon when recording, or make the tray icon color change to green color.
Edit: Also there is a bug in 1366x768 now. A green bar appears in the left side of the video recording when using original mode. If using 720p the green bar doesn't appear.
crl2007
Re: Action! 1.1.0
Sat Nov 19, 2011 3:51 pm
And maybe you can add more picture formats for screenshot in-game. For now it only outputs bmp, but I like to use png or jpg too. BMP are too big.
Thanks in advance.
Re: Action! 1.1.0
Mon Nov 21, 2011 9:30 pm
crl2007 wrote:And maybe you can add more picture formats for screenshot in-game. For now it only outputs bmp, but I like to use png or jpg too. BMP are too big.
Thanks in advance.
This will be added :)
crl2007
Re: Action! 1.1.0
Mon Nov 21, 2011 10:05 pm
Great news, thank you.
MaksFearless
PC Specification: ----
Re: Action! 1.1.0
Tue Nov 22, 2011 7:06 pm
does not record video games:
L.A. NOIRE (2011)
The Adventures of Tintin (2011)
FIX Please
Desypher
PC Specification: PC
Re: Action! 1.1.0
Fri Nov 25, 2011 6:18 am
There's another bug. When you try to rename the files from within Action!, after you finished recording a game/desktop mode OR after you just opened the app, will crash. I tried to duplicated this 4-5 times and event log will prove it :) .
OK, more testing.. it seems that, after I type the filename and hit enter, Action! crashes when it tries to re-generate the video thumbnail.
EDIT: I did some recordings on some of the latest games, without any problems on most of them.
Edit2: The audio won't sync up in MW3.. I tried everything. I played the .fic with the Action! player and Splash, the audio is delayed by 2-3 seconds. (This is the only game i have problems with when it comes to record capture/record it).
Re: Action! 1.1.0
Fri Nov 25, 2011 12:32 pm
MaksFearless wrote:does not record video games:
L.A. NOIRE (2011)
FIX Please
Hi, can you please provide more detials:
- do you see Action! HUD in this games?
- can you make screenshots?
MaksFearless
Re: Action! 1.1.0
Sat Nov 26, 2011 5:36 pm
Ghost, At that time and again that HUD is not visible in the game, program "Action!" does not recognize these games. In any case, you should test for these games, the program to understand what the problem is. I do not think this is a problem of my computer, because in other games HUD shows and recording is done properly.
Re: Action! 1.1.0
Sun Dec 18, 2011 8:51 pm
icsterm wrote:...
Should be fixed now in 1.2.0. Starting from 1.2.0 Action! records 1360 wide video in desktop fullscreen mode.
This provides sharp picture and eliminates problem of green lines.
Thanks in advance.
Added in version 1.2.0 :)
L.A. NOIRE (2011)
FIX Please
Investigating...
