Page 1 of 2
Mic crackling sounds
Posted: Mon Jan 12, 2015 10:51 am
by Pit
Hi! I'm having a lot of issues with audio lately, specially with Dragon Age: Inquisition. Now I'm having crackling sounds in the mic audio from time to time, but not in the game audio. I don't know, maybe it has to be with the desync problems.
Example:
http://youtu.be/CkBcR7yx7ng (I disabled game audio)
It happens with AVI or MP4 AMD APP or MP4 Intel Quick Sync. My CPU usage when recording with this game is 40%-60% (maybe less in the cinematics) and I have all drivers updated.
Specs:
OS: Windows 7 64 bits
CPU: Intel i7 4770 @3.40 Ghz
Video Card: ATI R9 270X
Webcam: Logitech C920
Mic: Blue Yeti
Current Driver version and date: Catalyst 2014.1120.2123.38423
Memory: 16 GB
Monitor Resolution: 1920x1080
Recording mode: Game/Application
Framerate: 30
Audio: AAC or PCM (Stereo, 48000Hz)
Thanks
Re: Mic crackling sounds
Posted: Tue Jan 13, 2015 1:54 pm
by Pit
Posted: Fri Jan 16, 2015 4:26 pm
by radi
Does your issue occurs only with this particular game or in general?
Posted: Fri Jan 16, 2015 9:51 pm
by Pit
Well, it happened in another game but it's an alpha game so maybe it's because it's bad optimized. But for now yes, only in Dragon Age: Inquisition (same with the desync problems).
Posted: Sat Jan 17, 2015 11:00 pm
by LRS
I have the same problem, but with Minecraft.
Every time I try to record, there's crackling sounds, and I know it's not my microphone because when I'm on skype or an audio recording program it doesn't crackle.
Posted: Tue Jan 20, 2015 2:05 pm
by radi
Pit wrote:Well, it happened in another game but it's an alpha game so maybe it's because it's bad optimized. But for now yes, only in Dragon Age: Inquisition (same with the desync problems).
Please report this to our support team. They will try to recreate your issue in our lab.
Posted: Tue Jan 20, 2015 9:08 pm
by Pit
radi wrote:Pit wrote:Well, it happened in another game but it's an alpha game so maybe it's because it's bad optimized. But for now yes, only in Dragon Age: Inquisition (same with the desync problems).
I did it, thanks
Posted: Sat Jan 24, 2015 7:45 am
by Protector101
I am also having this problem as well using different games. I am also using a Blue Yeti mic, Windows7 64bit.
Thank you.
Posted: Wed Jan 28, 2015 5:13 pm
by Becoming
I'm getting static/crackling both for the in-game sound and my mic, which never happened in prior versions. I have not changed any hardware or messed with any sound drivers.
Posted: Thu Jan 29, 2015 3:38 pm
by Quaglinoman
Same, using version 1.21 I get a fair amount of crackling, to the point I do nto want to post videos, it comes and goes. 4 game, no issues. I play Elite Dangerous with Oculus Rift....BOOM!! I get it.
Though I do not want to, I refuse to make a version 4 play through of the game, so I will post with an apology to viewers, I will be citing Action! as the issue.
I am using the Blue Yeti with a Pop Filter, Windows 7 64bit Pro
