Action 2.7.4 Audio Sync Issues
Posted: Thu Oct 05, 2017 8:06 pm
I´ve finally purchased ACTION, after testing it. Only to find out that unfortunately, screen captures that go longer than 7 minutes shows audio out of sync. I´m currently capturing at 60fps 1080p in MP4 format. This is the latest version 2.7.4.
Being able to use NVIDIA processing, was THE most important reason to puchase this product.
If you tell me I should settle for 30 FPS to solve the problem, means your product is not fulfilling advertised expectations.
If you tell me I should capture in AVI, then, I should really forget about ACTION and use FRAPS.
The audio goes out of sync dramatically at 5 minutes. When you get to about an hour of recording, the audio could get delayed to about 3 seconds.
I´ve been reading on tht forums that there was an option in ACTION to have constant frame rate capturing, for now ACTION uses variable frame rate.
This has all been said and done since version 1.x. Now 3 years later I cannot believe you are in ver. 2.7 and you are still having these issues. I would really need and answer or a course of action. Right now I´m regretting my purchase.
Please help.
Thank you.
Please help.
Thank you.
