m4r
PC Specification: Nvidia GTX 960M, Intel i7-6700HQ W10
My solution to recording Minecraft in fullscreeen (Nvidia only)
Sat Jan 06, 2018 8:07 pm
Hi, I had problems with rec minecraft and found a solution, which at least works for me.
in Nvidia control panel use
  • predefined graph: Nvidia
  • Antialasing -> supersampling (2x or 4x or 8x)
  • Threaded optimization -> enabled.
NOT use:
  • Antialasing -> controlled by application or multisampling = crash when you open Action.
  • Threaded optimization -> auto / disabled = crash when you open Action!.
in game if you use optifine mod:
  • antialasing >= 8
My config: (spanish)
my optifine conf.
if you not use optifine mod and in any case get a crash anyway, try to activate antialasing from the control panel. "antialasing mode"
if you have forge (mod tool) you need to open Action! after starting minecraft because minecraft not starting.
if you use minecraft Vanilla (not mods) you should be able to open minecraft and with before open Action! without problems with these settings.
Excuse my English. regards.
note: there are more configurations that do not cause crash, but this is one that has worked for me.
TheSuperMango
PC Specification: Nividia GTX 1050TI
Re: My solution to recording Minecraft in fullscreeen (Nvidia only)
Thu Jun 14, 2018 6:01 pm
YESSSS THANK YOU THIS WORKED FOR ME OH MY I HAVE TRIED SO MANY SOLUTIONS AND THIS WORKS THANK YOU
SquidKidNow
PC Specification: Windows 10, gtx 1050 , intel i770
Sun Jul 14, 2019 3:02 am
THANK YO SO MUCH
SuperSpeedster
Tue Nov 03, 2020 2:53 pm
Thank you very much for your help!!!
