Cannot Drag
Posted: Tue Apr 06, 2021 8:51 am
by DEViANCE
I have dual screen setup and usually I drag the mirillis action screen to my second monitor, but for some reason it won't let me, every other program i can drag across, but Mirillis won't, can't for the life of me figure out why.
Thanks in advance.
Re: Cannot Drag
Posted: Wed Apr 07, 2021 6:14 am
by Piotr
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
