bKay
PC Specification: Ryzen 5 1600, GTX 1050 Ti, Win10 (21H1)
4.20.2: ... doesn't detect STEAM GAMES!
Sat Jul 24, 2021 5:49 pm
Hello guys,
right now I'm having some issues with Mirillis Action. Version: 4.20.2.
I started 4 different games on Steam, none of them are detected by Mirillis Action.
The game is running on my first monitor. Mirillis Action is opened on the second so I can actually use the "Preview" to see the game running on it and being recorded.
The HUD doesn't appear and the "Preview" is just telling me the standard "text notice": 'Make sure a game is running and use the key to record it'.
THe record button is greyed out. So there is no recognition by Mirillis, although a game is running all the time.
What's going on, how do I fix this?
Can someone help me out?
Thanks...
Greetz 👌🏼
Watchman
Re: 4.20.2: ... doesn't detect STEAM GAMES!
Tue Jul 27, 2021 1:30 pm
Hi bKay,
Does this happen on all titles? Please send us the title of the Window of the game (or the game title itself so we can run tests in out lab).
Thank you.
bKay
Wed Jul 28, 2021 1:22 pm
Hey Watchman,
the game title is: "RESIDENT EVIL 5" (on Steam!)
I actually tried a few other games aswell. NONE of them are working, such as:
• Combat Arms: Reloaded
• Counter-Strike: Global Offensive
• Grand Theft Auto: San Andreas
• Mount Your Friends
• SpeedRunners
• War Rock
... these are just some of the games in my library and it doesn't matter which game is running, mirillis just won't detected them in "Game"-mode.
EXRTAORDINARY: I also have a physical CD-exemplar of the game Resident Evil 5. I installed it - for testing purposes - and launched it. / It worked and I could record normally in game mode, because Mirllis then just decided to actually detect the game.
So I'm still pretty sure, there are some problems with Steam...
Watchman
Wed Jul 28, 2021 5:47 pm
Just tested:
• RESIDENT EVIL 5
and they all work in Game mode. If this would be a bug in Action! we would be probably flooded with thousands of emails.
Do you use some kind of additional overlay in Steam?
bKay
Wed Jul 28, 2021 8:33 pm
Just tested:
• RESIDENT EVIL 5
- For real? Can't believe it. How? It still doesn't work for me on the other hand... can't be...
No, I don't... I just don't know. What could be the issue. What else is stopping Action! from doing his work probably?
Watchman
Fri Jul 30, 2021 9:12 am
Hi bKay,
Please go to folder:
C:\Users\<your user name>\AppData\Local\Temp
In this folder log files are created for every game in Game Mode. So for example for Resident Evil 5 you should see rt5_action.log.
Can you see this file???
bKay
Fri Jul 30, 2021 2:45 pm
It is called "re5dx9_action.log"
It has just one line: DLL_PROCESS_ATTACH (UWP: 0)
... So... What does it mean?
Watchman
Fri Jul 30, 2021 6:00 pm
That Action has properly connected to this game and you should see the HUD :/
bKay
Sun Aug 01, 2021 11:38 am
NO BUDDY, that's wrong!
Sorry for actually correct you, but...
I just started CS:GO and somehow it worked, this time it was actually recognizing the game.
However... I just opened the "log.-file" and it was saying THIS:
DLL_PROCESS_ATTACH (UWP: 1)
D3D9 present seen
So there must be something wrong with the game files...
bKay
Sun Aug 01, 2021 12:11 pm
I think I know what's causing the issue.
I just google "Resident Evil 5 Mirllis Action enb", then I found a thread (created in this forum), that ENB-mods and SweetFX aren't really get along with Mirillis Action.
People were asking for a fix, that was in 2013, did anything changed since then?
That would explain why the disk version (the originally without graphic mods), was connected probably with Action, but the Steam version, which has the mod installed, is not...
I will try to remove the mods and give it another try, if it doesn't work... then I'm just gonna give up on it.
