How to record aditional audio output
Posted: Sat Oct 16, 2021 6:17 pm
by jvmagni
So I've setup Voicemeeter to record my discord sound separate from the game audio. It works fine with Dxtory but I purchased Action and could not find the right option to add an aditional audio source. I can only record the main audio output and mic. Is there any option to add this secondary output like in Dxtory?
Thanks!
How to record multiple audio outputs (in game + Comms)
Posted: Sat Oct 16, 2021 9:08 pm
by jvmagni
I'm wondering if it's possible to configure Action multiple audio outputs channels. I have Voicemeeter configured and used to record with Dxtory. Since I bought Action I can't find an option to record this second audio source to separate my in game audio from my discord/communication audio. What should I do?
Re: How to record aditional audio output
Posted: Wed Oct 20, 2021 6:07 am
by Piotr
There is an option called "Enable/disable additional audio recording into separate audio file" below Secondary Sound Device.
You can also use audio recording feature in Action!
