barbaroes
PC Specification: Windows 8.1
MP4 problem with Vegas
Sun Jul 19, 2015 9:12 pm
When I record on MP4 (AMD APP) at 1080p 60 fps and recording the microphone separate, when imported to Vegas, only the audio is there and there is no video. Is there a way to fix this because it's frustrating. Thank you!
Dread_Boy
PC Specification: Intel i7 2600, Radeon 7850 DirectCU II
Re: MP4 problem with Vegas
Wed Oct 21, 2015 7:11 pm
If you record microphone and system sounds in same channel, it works.
I also found out if you choose AVI as file format, Sony Vegas will display video track but VLC won't be able to play it.
Tue Oct 27, 2015 5:56 pm
Dread_Boy wrote:If you record microphone and system sounds in same channel, it works.
VLC does not support AVI video codec FICV.
Return to “Video editing”
