johnsmithui
PC Specification: i5 RTX, 11
Re: Mirillis Splash Player Pro v2.0
Mon Dec 01, 2025 12:27 pm
Yep, this is a known issue with Splash Player. Motion Boost is very CPU-heavy, and high-bitrate 1080p or Blu-ray files often stutter even on strong PCs. 720p works because it's easier to process. Try lowering Motion Boost, disabling Light Boost, or switching to GPU decoding. You’re definitely not the only one experiencing this.
bigbear
PC Specification: win 10 pro
Mon Dec 22, 2025 2:12 am
Thanks for the detailed explanation, no wonder my computer, which has decent specs, always stutters when I turn on 1080p. I'll try turning off Motion Boost and switching to GPU decoding to see if it's smoother, because watching movies where the picture lags behind the sound is really frustrating.
Return to “Splash 2.0”
