Splash 2.1 bad sync Windows Red-stone 3
Posted: Tue Oct 24, 2017 2:24 am
Hi there...
I've already send a email to technical support but still no reply form them.
So,
Found Splash 2.1 problem with Windows Red Stone 3. So my problems is in Windows Red Stone 3, lags on HEVC/X265 videos. Lag means voice and video is not sync correctly. Voice is moving forward faster than video. This is keep happening when "Motion 2" is enabled and without motion 2, video is playing normally and everything is fine.
To clear the issue i have installed Windows red stone 3 on another computer and checked HEVC/X265 movies with splash 2.1. It's happening on both computers.
Any recommendation?
I am using Splash for over 3 years now. This isn't any hardware issue becasue it used work really well until windows upgrade to red-stone 3 for over 3 years.
Thank you!
So,
Any recommendation?
Thank you!
