File Types Association Bug
Posted: Wed Aug 14, 2019 3:27 pm
Upon a fresh Install of Splash (Latest Version) - You can see that the player comes with various Icons for all the supported files (MKV, MP4, AVI, etc)
After install, Splash Player does not make any associations with supported file types. There is not any option to do so either.
One has to manually set these file associations. This was not a problem in the past but after completely uninstalling and Re-installing multiple times, checking Permissions for files / folders, there is no file association.
It seems that Splash is trying to behave more like an "App" rather than a proper application.
You cannot simply double click and open files any longer. Is there anyway to register/unregister file types to make Splash the Default / Not Default player?
Is there any fix to this?
