Re: More Subtitle Options Please
Thu Apr 14, 2011 9:51 pm
Bazikcho wrote:Is there a reason "Move subtitles down Right Shift + ArrowDown" to move subtitles beyond bottom of the screen ?
I thing it will be better max down to be the end of the screen.
I think this is to be improved.
Cannot remind any argument to keep it possible to move outside the display.
monkeyman
PC Specification: Pretty good one.
Contact: ICQ Website
Sun May 01, 2011 8:18 am
Ghost wrote: I think this is to be improved.
Please, spend some time on subtitles for the closest update. This is probably one of the worst parts of your player. At least add turn on/off external subtitles with right mouse button and hotkeys to synchronizing subs. Ah, and yes, 5000 msec is NOT enough sometimes - you'd better turn of the limit at all.
Bazikcho
PC Specification: AMDx2 2.5Ghz - 4gb - 780G - 1TB - win764
Thu Aug 25, 2011 5:36 pm
One more thing for this option. Can you make it, too remember the last place i set subtitles.
It's annoying when I watch episodes and when one end, i press next > next episode ( file ) stars everything is ok but when subtitles start they are not on the same place. Every time they are on default position. Episodes are from dvdrips and black bars are on the same position.
"When I wrote this only God and I understood what I was doing...
Now only god knows !"
ertan.kucukoglu
Sat Sep 10, 2011 11:32 am
Well, everybody have different needs. Mine is to have a shortcut for micro subtitle adjustment. I remember that I read it somewhere in the forum. As far as I see, these shortcuts are still not present.
Can I hope something for next update? :)
ionutph
PC Specification: Intel I5 2500K, 560 Ti, 4Gb XP SP3
Sun Sep 11, 2011 11:35 pm
For all my movies I use bsplayer and the standard subtitle font is perfect. The only adjustments I use is subtitle position and font size in steps of 1. I have payed for Splash Pro to support the team and hopping that one day the player will be usable. The default subtitle is ugly, row spacing is to much and font sizes are limited.
