Miguel
Re: Audio Desyncing in Games and Applications Mode
Mon Sep 10, 2012 12:46 pm
Ok I did some encoding tests this evening, the audio desync happens only when the encoder is set to encode audio in 44KHz.
As Action! records audio in 48KHz, I tried encoding in 48KHz and there is no more audio desync :)
Can you try it Stevetastic?
Stevetastic
PC Specification: i5 3.4ghz, NVIDIA GTX670, Win 7
Mon Sep 10, 2012 1:02 pm
Thanks for your post but the desync I get occurs in the Action! .avi files. It's not an issue created by exporting from Action! or by any post production work. I've moved on to a product that works.
Lightning-kun
PC Specification: Windos 8, GTX660, Core i7, RAM 16Gb
Sat May 18, 2013 2:32 am
I have the same problem here.
17Goober17
PC Specification: Windows 7
Wed Sep 03, 2014 9:12 pm
I'm also having trouble with this too. I've been recording Minecraft for my channel and the sound is about 5 seconds delayed no matter what time in the video it is. I hope you guys can figure out what this is and fix it soon :(
FunBoy
PC Specification: Nvidia gtx 760 8.00 GB Windows 7
Fri Jun 05, 2015 12:00 pm
i HAVE the last action mirilis update and i have delay did someone made it work please help
Mon Jun 08, 2015 5:44 pm
Please notice that this is only a community forum. If you did not received any help here I recommend to contact our support team directly via support@mirillis.com.
