kulbhushan
PC Specification: win8
Re: ACTION! 1.12.0 & 1.12.1
Tue Nov 13, 2012 5:40 am
I used "Mirillis Action ver1.8" in
win7 for screen recording... it works great....
But It is not working in win8. .
I even tried ver1.12
. It gives error as- "Action_x86.bin" was stopped working, and then crashes at start
.. Can anyone help..
my system specs-- mercury pi945gcm mobo, intel dual coe: 1gb ram, onboard gpu. and win8.....:(
marciomachida
Tue Nov 13, 2012 11:11 pm
Desktop record cancel my audio with this new version.
Only microphone record.
Kashimus
PC Specification: windows 7 ultimate x64
Wed Nov 14, 2012 7:07 pm
THis version still not compatible with teamspeak overlay, still crashes.
DBTopper
PC Specification: I7 920, 2x GTX580, Win 7 64bit
Thu Nov 15, 2012 8:08 pm
I miss a Shutdown function after uploading on Youtube, but great program :D
Sry for my bad english ;)
Greetings
DBTopper
Fri Nov 16, 2012 11:52 am
marciomachida wrote:Desktop record cancel my audio with this new version.
Do you use option to record microphone into separate audio track?
Dahnark
PC Specification: I7 3770k GTX 670 Windows 7 64Bits
Fri Dec 07, 2012 3:32 pm
The option record the microphone in other file, not as second audio stream in the .avi should be added.
Because the adobe premiere and sony vegas doesn't detect the two audios and when I render it, it takes a lot of time (some error I don't know, while if record with only 1 stream the time is reduced a lot of.
Sorry for my english I am spanish xD
minomk
PC Specification: i5 750, 8GB DDR3, GTS 250, Win8 64bit
Fri Dec 07, 2012 11:41 pm
I want to report that with the last 1.12.x version of Action!, you can't upload AVI file on YouTube. It fails.
I don't want to convert the original source of the recorded video.
If I convert, I'll loose the original quality of the source video?
Sat Dec 08, 2012 11:03 pm
Dahnark wrote:The option record the microphone in other file, not as second audio stream in the .avi should be added.
It's Adobe and Sony fault that they don't allow their users to import files with more than one audio path. As for Sony Vegas, it's working with files where the audio is stereo.
minomk wrote:I want to report that with the last 1.12.x version of Action!, you can't upload AVI file on YouTube. It fails.
We will check that.
Kameronfox
PC Specification: AMD ATHLON . DUAL CORE 64x2 2GHz 2gb Ram
Sun Dec 09, 2012 11:20 am
Hey! ACTION! 1.12.1 not working video recording. When i press F9 it's minimized and it's not recording ?? it's bug ? or somthing wrong in my computer. My os is Windows7 . 1.9 is working my computer good. But 1.12.1 is not working . Any solution?
Thanks.
jimquim
PC Specification: win 8
Tue Dec 18, 2012 2:51 am
We will check that.
so did you check it i need to not convert to then i will just use another software thanks
