Nielo TM
Re: Splash PRO 1.8.0
Mon Jun 13, 2011 1:55 am
Ya I've noticed
azbest
PC Specification: x4-945 Hd6670 Win7x64;T7100BCM70015 Win7
Thu Jun 16, 2011 7:03 pm
Broadcom Crystal HD (bcm70015) support is qreat.
I found that m2ts 1080p files are downsampled to 720p, but wmv mkv and mov files are played with original 1080p resolution.
If i rename the m2ts file to mkv then Splash pro will play it in 1080p resolution, too ;)
Thu Aug 11, 2011 12:14 am
EvertonMonkey wrote:Any update on my previous post? Thought there would be some kind of response even just to say it's been looked at :-(
There should be no changes in Splash that cause the prolem to appear again. Do you have all basic video controls in playback options reset?
Do you use any Picture2 enhancements?
tuvi123 wrote:What about BOLD subtitles support? and the ability to choose subtitle font size by numbers?
also still no IDX/SUB support.
BOLDs and font size mprovements will abe available soon.
IDX/SUB is included in plans fo longer future.
azbest wrote:Broadcom Crystal HD (bcm70015) support is qreat.
Thanks for a feedback!
Do you encode video from m2ts to mkv or you just change the file extension to mkv?
P.J
Wed Aug 17, 2011 10:23 pm
Please share your problem here too:
http://www.mirillis.com/forum/viewtopic.php?f=18&t=2302
