Bazikcho
PC Specification: AMDx2 2.5Ghz - 4gb - 780G - 1TB - win764
Re: Thumbnail movie strip icon in folder gone...? -Please He
Tue Jul 26, 2011 4:00 pm
I fix mine :)
The problem is in windows of course :)
I have k-lite codec pack from the time when i don't have Splash :twisted:
Run Win7DSFilterTweaker.exe then open "preferred codecs" > You have too see something like that
Changed all file types on ffdshow from M$ ( or this u have not have Thumbnails or u want ) :arrow: Apply :arrow: exit Now maybe u need restart or Re-log. If not work :arrow:
Then remove splash association from file to none. Restart or Relogin :) and u are done :)
And they are here, associate avi files again to splash :geek:
"When I wrote this only God and I understood what I was doing...
Now only god knows !"
Thu Aug 11, 2011 12:26 am
Thank you guys for your feedback.
This confirms the problem with some Windows registry entries (probably).
P.J
Thu Aug 18, 2011 7:22 am
Also check this:
P.J
Thu Aug 25, 2011 8:57 am
I got the same problem with mpg extension after I checked this then set WMP as default but no use :?
P.J
Fri Sep 16, 2011 4:44 pm
All of my mpg and mp4 thumbnails are broken :cry:
Any solution?
P.J
Sat Dec 10, 2011 8:18 pm
Finally, I solved my problem!
It was because of dBpoweramp :D
http://forum.dbpoweramp.com/showthread. ... b71638a8a0
Thu Mar 22, 2012 12:24 am
P.J wrote:Finally, I solved my problem!
Thanks for sharing the solution.
As we have noticed so far all this problems are connected with 3rd party s/w.
