P.J
Re: Splash PRO 1.11.0
Wed Aug 31, 2011 8:41 pm
Do you have Vista/Win7? Enable Aero to get rid of stutter and no need to do it.
ertan.kucukoglu
Thu Sep 01, 2011 5:58 am
I have Win7, and Aero is already enabled.
P.J
Fri Sep 02, 2011 8:34 am
You can try Basic theme or disabling hardware acceleration (but compare CPU usage with HW enabled) to get rid of overlay.
Don't forget to get the latest graphic driver from intel.com
I know it's not the answer to your problem, only about overlay.
ertan.kucukoglu
Sun Sep 04, 2011 7:49 pm
Do you refer to win7 basic theme? Sorry, if that question is not a good one. I am quite new to splash.
vivan
Thu Sep 15, 2011 4:38 pm
Under Windows 8 (Dev Preview) only overlay video output is available, so no GPU decoding...
On the other hand - it doesn't switch to basic theme.
Plus
P.s. looks that this is because of renderer - in MPC madVR also doesn't work.
PS Vita, Nokia N8
P.J
Fri Sep 16, 2011 7:50 pm
We have still problem with Win7 :D
pirotrav
PC Specification: i7 2600k, radeon hd6870, 8gb RAM, win7
Wed Sep 28, 2011 5:46 am
When can we expect 1.12.0? Seems to have been a while between releases. JW.
P.J
Tue Oct 04, 2011 6:23 pm
They're working on Action! and other new versions like SplashBD.
It's better to report bugs here to help them :)
bolach
PC Specification: Amd fx8320, gtx650, Win7 x64, Realtek au
Wed May 09, 2012 1:08 pm
This player have badly audio quality.
P.J
Thu May 10, 2012 6:09 am
bolach wrote:This player have badly audio quality.
What do you mean, bad audio quality?
