vivan
Re: Splash PRO EX 1.11.0
Sat Sep 10, 2011 11:30 am
Yes, without hardware acceleration CPU load will be much higher.
Since videos have such big number of ReFrames really rare - it's better to switch it on, when your will play other videos. And only if your have such problematic video again (artifacts with hardware acceleration) - switch it off again (only for that video)...
Anyway, it's really easy - you don't have to restart player (like other players like MPC, PotPlayer and so on) - just use seeking (after switching hardware acceleration on/off).
That's why I have a suggestion for Splash - fallback to software video decoding if GPU isn't able to decode stream properly (e.g. intel + big number of ReFrames, or nVidia VP3 with 1024xXXX videos)
PS Vita, Nokia N8
Marsianin
PC Specification: Core i7 965, 12Gb, 2xGTX280, Win7 x64
Mon Sep 12, 2011 9:20 am
1. Please ADD SHUFFLE BUTTON in playlist.
2. It's trying to play hidden desktop.ini file when starts from the beginning and shows error.
3. I have a lot of videos with audio problems when SPDIF/Optical is used.
This video file plays fine with all audio settings except SPDIF/Optical. With SPDIF it sound disappears for a second every minute
Code: Select all
General
Complete name : Breaking Bad s04e06.mkv
Format : Matroska
File size : 1.46 GiB
Duration : 47mn 20s
Overall bit rate : 4 426 Kbps
Encoded date : UTC 2011-08-25 18:19:11
Writing application : mkvmerge v4.2.0 ('No Talking') сборка от Jul 28 2010 18:38:23
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format_Settings_GOP : M=2, N=4
Muxing mode : Container profile=Unknown@3.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 47mn 20s
Bit rate : 4 041 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.183
Stream size : 1.31 GiB (89%)
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4041 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec ID : A_AC3
Duration : 47mn 20s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 130 MiB (9%)
Language : Russian
Thu Sep 15, 2011 8:52 pm
Marsianin wrote:1. Please ADD SHUFFLE BUTTON in playlist.
Hi, shuffle is planned to be added.
We will investigate problem with SPDIF. Thank you for reporting.
