Re: Splash PRO sound management questions !!
Fri Jul 27, 2012 10:34 am
Playback Options (Audio Tab) offers a few adjustments that may fix your problem with too loud audio. You can set volume to each of your speakers living to middle one (responsible for voice track) to 100 while others are lowered so you won't jump from your chair anymore ;)
dave1977nj
PC Specification: Intel i5 2500k ASROCK Extreme 4 Gen 3
Sat Jul 28, 2012 12:43 am
They should fix this issue. It's a main component of the player Video And Sound Why don't they fix the audio? Is the development dead? This is a good player but who is going to pay for something that doesn't work the way it was intended to? :(
msex
PC Specification: core i7, gtx 470, 12gb, win 7 - 64 bit
Thu Aug 02, 2012 11:22 am
radi wrote:Playback Options (Audio Tab) offers a few adjustments that may fix your problem with too loud audio. You can set volume to each of your speakers living to middle one (responsible for voice track) to 100 while others are lowered so you won't jump from your chair anymore ;)
its not helping because the voices of talking is from the center, but other effects as well! so if you will lower the center u will lower the voice of talking ! Mirilis should develop plugin like ac3filter thats allow you to raise up voice sound only!
