Re: Action! 1.13.0 & 1.13.1 with Action! Remote Control
Wed Feb 27, 2013 1:37 am
New Action! 1.13.1 update is now available.
Full change list:
* NEW FEATURE: Mark video recording as a favorite (CTRL+F)
* Fixed exporting of 2560x1440 video recordings (and other 16:9 resolutions larger than 1920x1080)
* Stability fix for video exporting
* Fixed allowing/disallowing of some hotkeys
* Added support for folder junctions
* Small GUI improvements
GamerGuy
Wed Feb 27, 2013 7:41 am
Maybe I'm imagining things, but the new 1.13.1 version seems to make my laptop fan run louder/longer than previous Action versions. Is there a link where I can get the prev version 1.13.0 to go back to?
triskele10
PC Specification: i5-2500k/gtx660ti/win8x64
Wed Feb 27, 2013 11:58 am
After the latest update there's a stutter when I record a game play.
Rikudou
PC Specification: Windows 7
Wed Feb 27, 2013 1:09 pm
I've got 'Check for Updates' ticked in Action but it doesn't seem to do anything, why's that? I know I can reinstall the program but it would be handy if that part worked - I've tried restarting the program several times.
kniff
PC Specification: i7 2600k@4.3Ghz/GTX 970 SLI/16GB RAM
Wed Feb 27, 2013 7:44 pm
Clearly an issue with stutter every 4-5sec with newest version! Works fine with 1.13.0 with same settings - but when upgraded to 1.13.1 it stutters.
Another guy made a topic with same issue : http://www.mirillis.com/forum/viewtopic ... 36&t=28206
Hopefully you can fix this soon :)
Rikudou
Wed Feb 27, 2013 9:38 pm
triskele10 wrote:After the latest update there's a stutter when I record a game play.
Been trying to record as well the last few hours and I'm experiencing the same thing. Any update on this issue?
Thu Feb 28, 2013 12:00 am
We already found a cause of this issue. Fix will be included in 1.13.2 which will be ready within next few hours.
Rikudou
Thu Feb 28, 2013 12:12 am
radi wrote:We already found a cause of this issue. Fix will be included in 1.13.2 which will be ready within next few hours.
Awesome news, thanks for the update :)
Re: Action! 1.13.0 - 1.13.2 with Action! Remote Control
Thu Feb 28, 2013 1:43 am
New Action! 1.13.2 update is now available with hotfix for problems
on Windows 7 after installing Platform Update for Windows 7 (KB2670838).
Change list:
IMPORTANT: All setups with Intel HD graphics cards require the latest Intel graphics drivers to be installed.
* Fixed Action! HUD and desktop recording for Windows 7 with Platform Update for Windows 7 installed (KB2670838)
* Fixed periodic stutter during some games recording (folder junctions support removed)
Laurent13
Sat Mar 02, 2013 11:47 pm
Update is fast, useful and highly anticipated thank you for all stuffs. :geek:
