RazrBit
PC Specification: I7-3770K, HD6950, 8 x64, 8GB
Re: Сodec capture to YouTube
Sun Apr 14, 2013 8:29 pm
Well, youtube added support for FRAPS raw files, not the other way around. So this situation would be the same. If it has enough demand, it might be added, or if devs request it. Though it's unlikely to happen anytime soon or at all.
Either way, they wouldn't tell you about it.
Novius
PC Specification: i7-2630QM, GTX 560M, 8GB RAM, Win8 (x64)
Mon Apr 15, 2013 8:07 am
Thank you all! I did some tests on your advice. But still to this turns into a "dancing with a tambourine." Easier for me to capture the video and immediately put on youtube, and now I have to add to this process the conversion to mp4, and it's too much time.
Novius
Fri Apr 19, 2013 11:42 am
Good day!
Tried your suggestions ... And the result of my steps:
1. Capture video of 1920x1080 60fps - 38 min
2. Converted to Auto profail (best settings) - about 50 minutes
3. Connect the video segments and export with avidemux - about 6 min
4. Uploading to YouTube - time did not measure.
5. Mp4 format obscures (darker) the picture in youtube compared with the original - not good.
Ideal for me:
2. Connect the video segments and export with VirtualDub - about 6 min
3. Start Upload to YouTube and go quietly to work
4. While I drive to work - all filled, and at work can only edit the names and publish videos.
A minimum of effort with excellent quality.
Is such an option is not possible to carry out ?
videogramez
PC Specification: i5 2500K, NVIDIA GeForce 560Ti, Win7 x64
Mon Apr 22, 2013 4:47 am
If Youtube is giving you trouble when you upload MP4 files you joined then copied to a new file with AVI Demux, try re-encoding only the audio (choose AAC instead of Copy) - this is still much faster than re-encoding the video as well.
Novius
Mon Apr 22, 2013 10:22 am
videogramez wrote:If Youtube is giving you trouble when you upload MP4 files you joined then copied to a new file with AVI Demux, try re-encoding only the audio (choose AAC instead of Copy) - this is still much faster than re-encoding the video as well.
I have no such problems.
I do not want to use the MP4 encoding (as the capture format - there is no way), I want to upload to youtube 1080p video captured with FICV codec.
Wed Apr 24, 2013 9:18 am
RazrBit wrote:Well, youtube added support for FRAPS raw files, not the other way around. So this situation would be the same. If it has enough demand, it might be added, or if devs request it. Though it's unlikely to happen anytime soon or at all.
Not really. Action! uses its own video codec, fraps doesn't. That's why fraps raw files are uploading fine.
