This might be a shot in the dark, and may not have any connection to your issue but perhaps the "Communications" settings is causing problems?
Try setting it to "Do nothing"...worth a try i guess.
Yeah Tried all his methods and have the same issue still... I did however get contacted by their support in reply to my ticket i sent and they are looking into the issue..Aullah wrote:Thanks for the help. It worth a try but nothing...
Dont think its a microphone settings problem because IT DOES record my sound... I think the problem is that the ACTION program does not recognize the key I bind in the setting for the "microphone recording"... because thats the bind I need, right?
Please share any info you get from support.sycoinc wrote:Yeah Tried all his methods and have the same issue still... I did however get contacted by their support in reply to my ticket i sent and they are looking into the issue..Aullah wrote:Thanks for the help. It worth a try but nothing...
the main thing is it records when its set to ALWAYS on but not the push to talk version of it.
I reinstalled my windows a week ago so its pretty clean.locutus wrote:What about just doing an new clean install of the program?
Or try updating your soundcard driver?
The problem support is going to have is they need to be able to reproduce the issue you guys are having, and without managing to pinpoint were this is coming from they just might not be able to help.
You should also try shutting down ALL unnecessary programs in the background, even things like Steam etc. or if you have a temp monitor running, Overclocking tools etc etc.
It was said many times, this is only a community forum, not a direct support line. If you are experiencing any problems with Mirillis software contact directly the support team via support@mirillis.com.locutus wrote:That's a shame. Not only about your problem, but the fact that this topic has gone unnoticed by any of the mirillis team. Seems like that is the case with many of the topics here.
But at least we tried to help you out.
