H.Shneilmanhousr
PC Specification: Windows 7
Re: Action! Crashes when I stop the video. Consistently.
Sun Jul 14, 2013 11:00 pm
Thanks, I think as long as people like you are supporting the community that It would be well worth the money. What are your parameters for Quick Sync recording? I think I remember seeing another thread that you posted that was your settings that you thought had the best results. Is that what parameters you were referring to?
Montago
Mon Jul 15, 2013 7:21 am
H.Shneilmanhousr wrote:Thanks, I think as long as people like you are supporting the community that It would be well worth the money. What are your parameters for Quick Sync recording? I think I remember seeing another thread that you posted that was your settings that you thought had the best results. Is that what parameters you were referring to?
yes...
although today its slightly changed...
when i play BF3, i've activated 2xAA and activated VSYNC ... but i also overclocked my GPU to 1000 mhz instead of 925 (ATI 7970) -- this helps tremendously, as it eliminates all the framerate drops that Action causes.
