Re: Action! 1.15.0 with LIVE Streaming
Fri Aug 02, 2013 4:44 pm
Mu6o wrote:Actually, you posted that somewhere when I asked you. About the steam version, that you wait for the livestream.
This is my exact quote:
radi wrote:As for the Steam, we are currently working on live streaming function. We would like to get on Steam with this function fully tested and correctly working.
I said that we would like to, not that Action! will come with Live Streaming and Steam together.
renesweb74 wrote:First I think the same - I bought yesterday and I thought Livestream Option is for free - please remove this.
Second I have the same setting like Laurent13. My Game (BF3) run in 1920x1080 - fullscreen. I try to stream (720p is maximal, 1080p is grey?). If I start to stream my game fullscreen goes in window mode (probably to 720p) - Now I go to fullscreen and the stream is ended. I want to play in 1080p and stream in 720p Its possible?
Request has been already sent to our tech lab.
Laurent13 wrote:Streaming seems broken but a file recording .mp4 ..
There you can see my configuration.
Check if you have your stream key properly typed.
The Fold wrote:To my main reason for posting. I can get the streaming working without any problems, but my question is if there are plans to allow recording and streaming at the same time? I know there is an option to record the stream already, but I am only able to stream at about 360p, but I would like to record at 720p/1080p. If this is not an option at the moment, is there scope for it in the future?
Also is there any scope for adding in scene management such as in OBS and Xsplit? I really like OBS, but Action is so much easier to record with I'd rather have one application to cover everything.
I don't think it's possible but I will ask our devs.
Montago wrote:I've setup Action with Twitch ...
but... is it true that LIVE Streaming only works in game-mode ?
I've only tested with Screen-capture so far .. and that doesn't work.
I'll test some more with Game-Mode when i get home...
BTW... Why does it cost a subscription, when some of the Streaming services are free ??
If i have 100/100 Mbit Fiber... and want to stream from my own computer... couldn't you then make that possible without a fee ?
The streaming feature works both for Game/Application mode and Desktop. It also works for Active Desktop Region. What exactly does not work with your desktop recordings?
The subscription plan is required due some licenses fees that Mirillis has to cover. I don't know all the details but it was explained on Mirillis facebook page.
Re: Action! 1.15.0-1.15.1 with LIVE Streaming
Fri Aug 02, 2013 6:35 pm
Action! 1.15.1 update is available:
Changes:
- Added option to record microphone into separate audio track for MP4 video recordings
- Video quality improvements
- Stability fixes
Laurent13
Sat Aug 03, 2013 2:27 am
I updated Action 1.15.1 and i have a delay between when i push the button for recording and when i talk. "Area Desktop Recording". There are some bugs i never had before. I begin to talk when the "R" appears but the delay is in my video.
1- For exemple, i record 4-5 seconds and when i watch the video, it during only 2 seconds with delay audio this is a big deal i don't understand what's going on this version. :cry:
2- I can't export the video file :shock:
Thanks for your help
Montago
Sat Aug 03, 2013 8:01 am
I did a lot of LIVE recording yesterday at 480p and 720p in various bitrates...
in ALL cases the audio was 500-1000 msec behind !!! (or desynced almost all the time)
take a look here : http://www.twitch.tv/montagodk (click on the videos to see old videos )
480p at 2000kbit seems to work the best for me (only have 5 MBit upload at home)
it was quite cool to see it working - but the audio problem is a little annoying.
ps. Version i used was 1.15.1
Laurent13
Sat Aug 03, 2013 10:37 am
Action Mirillis 1.14.2.0 works better than 1.15.1.0, no delay, bugs and no dash while i recording area.
Bu why ? :|
Thanks for your help Mirillis i love you software but 1.15.1.0 is bad to my side.
GamerGuy
Sat Aug 03, 2013 6:59 pm
Love the new separate mic track option for MP4. However it seems a little quieter than when I test the mic in my soundblaster control panel. Any way to boost the volume further?
Vibe
PC Specification: Bootcamp, Windows7 64 bit
Sun Aug 04, 2013 7:13 am
Your list includes Livestream, Ustream, twitch, YouTibe but Dailymotion is expected in the future ?
Sorry my english i am french :o
daniel44
Sun Aug 04, 2013 11:54 am
i have a problem with the live streaming.
when i try to stream my desktop it works fine but when i start a game and playing it there is audio but the screen is all black.
when i purt the game in windowed mode it's fine but the performance are bad because the game is windowed.
xdnbkingx
PC Specification: Intel i7 3770k, GTX 670, Windows 7 64bit
Sun Aug 04, 2013 1:02 pm
Doesn't matter how i set it up, i can't stream... there is no LIVE on the HUD and it just records.
Montago
Mon Aug 05, 2013 6:51 am
there is a checkbox in the LIVE tab... under the broadcast tab...
it says : "Recrod streamed video to disk"
try de-clicking that checkbox to disable local file recording... it worked for me !
also check that Status under the 'i ' tab says something different than 'Connection failed'
