Re: Action! Live streaming bug?
Wed Aug 07, 2013 12:38 pm
To which website you are trying to stream your videos?
xdnbkingx
PC Specification: Intel i7 3770k, GTX 670, Windows 7 64bit
Wed Aug 07, 2013 1:18 pm
Twitch.TV, i have no problem using OBS and Xsplit... so it must be the software
Wed Aug 07, 2013 2:41 pm
xdnbkingx wrote:Twitch.TV, i have no problem using OBS and Xsplit... so it must be the software
Are you sure that your stream key doesn't include any addtional characters? As far as I know if you copy the Stream key directly from the web there's a little annoying space character at the end. Try copying your stream key to notepad before you copy it to Action.
xdnbkingx
Wed Aug 07, 2013 2:57 pm
Yeah, that was it.... something so stupid haha. OBS and Xsplit must not care about the extra space, maybe shove that in as a tiny fix next update as it is so minor.
xdnbkingx
Wed Aug 07, 2013 3:04 pm
http://www.twitch.tv/xdnbkingx/b/442139446
Thats what just happaned when i streamed ^ i have 12mb upload and thats at 3mb.
Any chance of getting something to show if your dropping frames like obs and xsplit?
Edit - Just closed action and re-opened and now i am unable to stream and it just records... even when the box is unticked for record to while streaming. don't worry about writing back i think i will just give the live streaming feature a miss :)
Wed Aug 07, 2013 4:12 pm
Your playback was glitchy due upload speed. Check your upload speed via any speedtest any adjust your quality to your internet speed. Bitrate shouldn't exceed your upload speed.
xdnbkingx
Wed Aug 07, 2013 4:22 pm
That video stream was at the lowest... 3000 bitrate.
Thu Aug 08, 2013 7:34 am
xdnbkingx wrote:Image
Well, that makes it odd. If you would like to report this strange situation please contact our support team via support@mirillis.com.
Users browsing this forum: No registered users and 47 guests
