belboz
PC Specification: Intel i7-3630GM, Nvidia GTX 680M, Win 8
Re: Microphone record on button down doesn't work properly
Tue Aug 27, 2013 8:36 pm
Ditto the comments from Ars.
New version still has issues. I am holding my push to talk key and many times while playing a game it cuts out. I am definitely not releasing the PTT button.
Would love to see the PTT delay that Ars talked about, maybe even a noise gate feature to not record the ambient or quiet noises.
I hope the PTT issues can be resolved quickly. This really makes recording a pain.
belboz
Wed Aug 28, 2013 1:14 am
One thing I did to fix the push to talk issue (until mirillis fixes it in Action! itself).
I installed a global push to talk app that works with Windows 7 and 8.
So basically I can use this app to mute the microphone system wide until the push to talk key it is configured to is hit.
I then just have Action! set to record continuously. Has worked well so far. No real issues with cut out.
Arsb3llicA
PC Specification: i5 2500K, 2x GTX460 SLI, Windows 8 x64
Thu Aug 29, 2013 4:53 pm
Thanks for posting belboz, I'll be sure to check that program out but hopefully Mirillis will release another update soon.
