It would be nice to edit the channel list after scanning.
Possibly remove from the list and change the order by editing
BIG QuOTE!!! Anyway I love this playerjanek 77 wrote:It would be nice to edit the channel list after scanning.
Will try to comment all suggestions here... We keep adding new feature but we cannot add everything at one time so it will be added gradually. Some features will be available only in PRO or TV version.1 DVB-S, FM and Analog tv-tuner support.
2 Better subtitles font-size customization.
3 Option to change the height and font of subtitles.
4 PGS subtitles support.
5 FLV/F4V support.
6 Showing language and channels info on "Audio tracks" list.
7 WMV support.
8 DVD support.
9 Black bars crop for 4/3 videos that are actually 16/9 video.
10 Hebrew GUI.
11 Wider subtitles sync adjustment option.
12 Make the information window "hover" so it will be possible to move it in/out the player window and to change it's size.
13 Record option for tv-tuner.
14 My dvb card software (DVBDream ver. 1.4i) has an option to send the mpeg2 and h264 received streams to players using some kind of command line (see the attachement below). Can you add such feature to splash ?
15 I would add a setting to change the background color...
16 read metadata of mp4 video files
17 media library
18 import and export media library
19 normal lists and smart lists
20 preview in thumbnail in the same list/smart-list (like itunes)
21 possibilite for use divx h.264 codec (this one is best quality when you advance fast in 1 seg, 1seg the video..)
22 native support for 64 bits sistems.
23 It would be nice to edit the channel list after scanning.Possibly remove from the list and change the order by editing
24 i suggest to full support of styled subs such .ASS .SAA
