DKsDEVIL
PC Specification: I5 2500K, Gtx 770, win 7 64 bit,
Re: Action! 1.17.0 BETA
Mon Jan 13, 2014 12:13 pm
Montago wrote:
viera1905 wrote:Add Graphics Card processor heat indicator
why do you care ?
If the system is unstable you need to cool it better and stop overclocking irresponsibly :twisted:
If the system is NOT unstable... then frag some more !
Spot on :ugeek:
KyrenCross
PC Specification: AMD FX 8350,GTX 780,WIndows 7,Xonar D2X
Tue Jan 14, 2014 3:29 pm
Question:
If I install the beta will my previous installation be ovewritten or is the beta a separate install?
Also to those who use SweetFX or ENB, does the beta capture those effects now or not?
Thanks in advance to those who would answer ^_^.
Claunator
Wed Jan 15, 2014 2:47 pm
KyrenCross wrote:Also to those who use SweetFX or ENB, does the beta capture those effects now or not?
Apperantly no. I tried both for San Andreas and here's what came out: SweetFX didn't even let it launch, i didn't touch any setting files.
ENB didn't allow Action to detect San Andreas, even if i alt-tabbed to relaunch Action and switched to application mode and went back to SA, it crashed and didn't launch again.
stmalk
PC Specification: i7-3770, 3.4 Ghz, GeForce 660 Ti 2 GB
Wed Jan 15, 2014 5:04 pm
KyrenCross wrote:Question:
No, Mirillis doesn't work with any of graphic enhancements. Use something else instead.
MeiVincible
Thu Jan 16, 2014 1:11 am
If not changing the install folder during installation, it will overwrite the previously version of Action!
I see counter has been added to the HUD lately, but visibility really stinks on my monitor (24 inch, 1920*1200)
Why so small and grey color, when colors like blue, red or white would obviously work so much better?
Suggest better visibility with either larger numbers or different color.
evolution
PC Specification: 3770K, ASUS GTX670 Direct CU II, win7 64
Thu Jan 16, 2014 2:58 pm
cool, I am able recording quakelive gj
improved codecs thumbs up
but I am experiencing frame drops by ~30-45fps when using intel quick sync but what I found out it has something to do with playing on 120/144hz screen(when I switch to 60hz no fps drop) try already other games like bf4 metro tomb raider.. (e.g crysis3 I got 150fps, recording -> 85fps) using shadowplay has no fps drop not hdd bottleneck
Montago
Thu Jan 16, 2014 3:43 pm
evolution wrote: but I am experiencing frame drops by ~30-45fps when using intel quick sync but what I found out it has something to do with playing on 120/144hz screen(when I switch to 60hz no fps drop)
Action will eat some of the overhead ... about 20-30 % and if your computer is 'only' fast enough to render 130 fps and your monitor is 120 hz... then those 20% = 26-39 fps ...
If you play at 60 fps/hz then you wont notice because you still have overhead.
I got tired of that, so i changed from 1080p30 to 720p60 (high Q + QS) which is almost unnoticable...
720p is more than enough to "enjoy" watching replays, and 60p is more important IMO than resolution. 60p is exactly like i remember playing it, instead of 30fps jaggy gameplay.
too bad that Youtube only support 30fps :-(
Laurent13
Thu Jan 23, 2014 5:56 am
Montago wrote:
evolution wrote: too bad that Youtube only support 30fps :-(
