leszekgd
PC Specification: Q8200S, HD5450, Windows 7
Re: SPDIF Audio
Wed Jul 21, 2010 5:07 pm
I also would like to know if you are willing to introduce dts-hd and dolby truehd support or only the BD version will support those types of audio format. If yes then when all of this will happen?
nemesys
PC Specification: intel I5, Ati HD 5650, Windows 7
Re: SPDIF Audio
Sat Jan 28, 2012 6:05 am
zzzmurf wrote:Hi,
First I wasn't able to get audio via SPDIF. I'm using SPDIF via external Soundblaster X-Fi Surround. After the tip from neograniceni I deactivated the Sondmax integrated card. I now get sound and my amplifier detects the stream as DTS, but is sounds choppy like a broken record. Works fine in Media Player Classic.
Hello!
Same problem as my colleague. DTS or Dolby Digital sounds better in Media Player Classic Home Cinema. In Splash Pro does not.
Can anything be done about it?
Thank you!
Re: SPDIF Audio
Thu Mar 22, 2012 12:33 am
leszekgd wrote:I also would like to know if you are willing to introduce dts-hd and dolby truehd support or only the BD version will support those types of audio format. If yes then when all of this will happen?
Software HD audio decoding is not planned for non BD Splash versions.
nemesys wrote:
zzzmurf wrote:Hi,
Hello!
Thank you!
Do you also have X-Fi soundcard?
gon_dc
PC Specification: X6 1090t; HD6870; X-Fi Surround; Win7x64
Re: SPDIF Audio
Fri Apr 20, 2012 9:00 am
nemesys wrote:
zzzmurf wrote:Hi,
Hello!
Thank you!
I have the same problem, can't get sound throught SPDIF using SplashPro. It works using PotPlayer, XBMC.
My sound card it's an X-Fi Surround 5.1 (it's an external sound card). Is there any workaround to make it work?
Thanks!
zebedeu
PC Specification: Core2Duo E7400, HD4870, Win7 x64
Re: SPDIF Audio
Wed Jun 06, 2012 1:48 am
Hi people!
I have an generic audio card with chipset "Envy24 Family Audio Controller WDM" with optical digital output (s/pdif) and Splash Pro Player latest version does not recognize this optical output. Free players like PotPlayer works fine.
Any tips? Solution?
alizee
PC Specification: AMD phenom X4 970, HD5770, windows 7 32
Re: SPDIF Audio
Mon Jun 11, 2012 12:35 am
i have the same problem only on windows 7. On xp i have spdif with splash. SB is X-Fi
All i can say is the new and old and only creative drivers for x-fi cards in W7 is crap...
Im trying to get some modded ones and i will tell soon if i can get spdif in W7
my soundcard is X-FI Xtreme Music
zebedeu
Re: SPDIF Audio
Fri Aug 31, 2012 2:46 pm
Hi! the spdif problem is fixed in version 1.13.0????????
masterzeon1
PC Specification: i5 3320M,8G RAM intel HD 4000, WIN 7 64
Re: SPDIF Audio
Sat Feb 09, 2013 4:17 am
my soundcard is a USB - SB X-FI HD Xtreme Music
my Laptop is HP elitebook 8470p (WIN 7, i5 3320M, 8 Gb ram,intel HD 4000 ....)
im also trying to play MKVs with DTS thru SPDIF and im not getting the DTS audio at all, did also the suggestions and no go at all ...
it works fine with VLC and other players, hope we get this SPDIF issue resolved or else i will request my money back!
