pull lead
PC Specification: i7 3770, radeon hd 7800, windows 7
Re: TeamViewer + Action = Problems
Fri Feb 28, 2014 4:47 am
test post (sorry)
Cauptain
Contact: ICQ
Sat Mar 01, 2014 1:14 am
Abuser wrote:Okay I think I disabled it and the same problem still happens.
Every time I try and connect to my PC via TeamViewer and Action is open it won't let me. When I close action it lets me. I want to TeamViewer while it is open.
Why? Teamviewer can record avi video too. Only check this in settings.
Claudio
Abuser
Sat Mar 01, 2014 5:34 am
Claudio
I want to record with Action! not TeamViewer.
ShadowIce
PC Specification: Windows 8.1
Mon Jan 12, 2015 3:55 pm
Problem is caused by action_x86.dll crashing TeamViewer_Desktop.exe. If there's a way to prevent that DLL from hooking into TeamViewer_Desktop.exe that should fix it.
Fri Jan 16, 2015 4:32 pm
You can use exclude particular processes with exclude list feature.
MAGNETICO
PC Specification: INTEL I7 3720 NIVIDIA QUADRO WIN 7 64 B
Mon Feb 23, 2015 10:24 am
Dear Mirillis, my name is Stefano and recently I purchased Action. Fantastic software. I experienced an issue of compatibility between your program and teamviewer (Ver.10). Unfortunately I'm doing a course with a professor online and have the need to record the lesson with Action but when I start I close the connection with teamviewer.
Confident of your help I offer kind regards
Stefano
Rome Italy
I used google translate, sorry.
Users browsing this forum: No registered users and 61 guests
