MiRai
PC Specification: W10 x64
Re: Action is Not Recording in (GameMode)
Sat Mar 01, 2014 9:00 pm
I'll go ahead and add to this post, as well.
When trying to record World of Warcraft in DX9, Action game capture is working just fine. However, when I change World of Warcraft to use DX11, Action refuses to record the game. I typically use Windowed (Fullscreen), but regardless of display mode, I cannot seem to record WoW in DX11 through Action's game recording mode.
Active desktop capture works fine, though.
Talcym
PC Specification: Win7, Intel Core i7 920@2.67GHz 2.67GHz
Mon Mar 03, 2014 8:32 am
I am having the same issue in World of Warcraft windowed mode using version 1.17.4.0.
Paladin341
PC Specification: Windows 7, i7-2670QM @ 2.2 GHZ, 4GB RAM
Mon Mar 03, 2014 9:27 am
I am also having this issue.
MiRai
Mon Mar 03, 2014 4:45 pm
An update to my reply above...
After reinstalling 17.3 and 17.4 back and forth on top of each other a few times in order for me to get a better picture for what was happening to maybe provide better feedback, 17.4 began miraculously "recognizing" WoW when playing with DX11 and using game recording mode -- The Action HUD appeared and began showing that the game was running DX11. However, the moment I pressed record on Action, both the game and the program crashed. Action gave the following crash report:
Code: Select all
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	Action.exe
  Application Version:	1.17.4.0
  Application Timestamp:	52fe0e18
  Fault Module Name:	Action.exe
  Fault Module Version:	1.17.4.0
  Fault Module Timestamp:	52fe0e18
  Exception Code:	c0000005
  Exception Offset:	0005e170
  OS Version:	6.1.7601.2.1.0.256.4
  Locale ID:	1033
  Additional Information 1:	0a9e
  Additional Information 2:	0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:	0a9e
  Additional Information 4:	0a9e372d3b4ad19135b953a78882e789
I'm not sure if that's helpful, but ever since the crash happened, I've been able to flawlessly launch Action v17.4 (when Aero is enabled w/o an apu2enc.dll crash) and record WoW in DX11 using any capture mode. I fear what might happen when I need to restart my machine. :)
sinnfullduck
PC Specification: i7 2600k, radeon 6870, win7
Mon Mar 03, 2014 8:54 pm
I'm using version 1.17.4 on Windows 7 and I have the same issue. With the previous version everything was fine and after upgrading to this one I can't use game mode.
SysL
PC Specification: i7-960>EAH6950/2DI2S/2GD5>Win7-x64
Mon Mar 03, 2014 10:21 pm
1.18 still continues.. please fix game mode!
Mon Mar 10, 2014 7:29 pm
Please send your feedback to support@mirillis.com. This is an isolated issue which does not occur with every user.
